#macro ReadLineData128()
SampleLine 'Sample line at 8MHz
GetLeftLightLevel 'Measure light level on pixel on the left side
GetLineState 'Store binary pixel data into Line_state
GetRightLightLevel 'Measure light level on pixel on the right side
SetIntegrationTime 'Perform mathematics on Vout to get Tint
#endmacro
#macro SIPulse()
high SI
pulsout CLK, LinePulse
low SI
#endmacro
#macro SampleLine()
SIPulse 'Start a sample
pwmout CLK, 1, 4 'Clock out some fast pulses (8MHz @ 64MHz clock speed)
pauseus Tint 'Allow for sufficient integration time
pwmout CLK, OFF 'Finish the sample
SIPulse
#endmacro
#macro GetLeftLightLevel()
Vout = 0 'Set light level to zero for each loop
pulsout CLK, LinePulse 'Pulse clock to start reading next pixel ...
readadc 10, pixel_data 'Measure voltage on pixel #4 for light intensity
Vout = Vout + pixel_data 'Add the value to the accumulator
#endmacro
#macro GetRightLightLevel()
readadc 10, pixel_data 'Measure voltage on pixel #124 for light intensity
#endmacro
#macro GetLineState()
adcsetup = 0 'Reset inputs to digital for digital read of 120 pixels
Line_state = 0 'Set line_state to 0 to avoid clearing individual bits
'Shift sensor data into variables in location 56 to 70
shiftin CLK, AO, 0, (@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc)
read @bptrdec, bit14 'Get pixel state from position 70 and put 1 or 0 into bits of Line_state
read @bptrdec, bit13
read @bptrdec, bit12
read @bptrdec, bit11
read @bptrdec, bit10
read @bptrdec, bit8
read @bptrdec, bit8
read @bptrdec, bit7
read @bptrdec, bit6
read @bptrdec, bit5
read @bptrdec, bit4
read @bptrdec, bit3
read @bptrdec, bit2
read @bptrdec, bit1
read @bptrdec, bit0
#endmacro
#macro SetIntegrationTime()
Vout = Vout / 2 'Obtain average of pixel #4 and #124 outputs
Select case Vout
case > Vtarget 'If voltage above target (saturation possible) ...
if Tint > TintMin then '... if Tint not already at minimum ...
Tint = Tint - TintStep '... reduce by TintStep to try to converge
elseif LEDPWM > LEDMin then 'In case Tint cannot be reduced, try to reuce LED intensity ...
LEDPWM = LEDPWM - LEDStep '... reduce LED intesity by LEDStep
pwmduty LED, LEDPWM
case < Vtarget 'If voltage below target (cannot see in the dark) ...
if Tint < TintMax then '... if Tint not already at maximum ...
Tint = Tint + TintStep '... increase by TintStep to try to converge
elseif LEDPWM < LEDMax then 'In case Tint cannot be reduced, try to increase LED intensity ...
LEDPWM = LEDPWM + LEDStep '... increase LED intensity by LEDStep
pwmduty LED, LEDPWM
endselect
#endmacro
#macro GetLinePos(line_state)
'Determine the position of the line
if line_state > 0 then 'If there is any line at all ...
line_width = NOB line_state '... find the number of set bits = line width ...
line_edge = NCD line_state '... find the highest set bit = rightmost edge of the line ...
line_centre = line_width / 2 '... store half of the line in a new variable to save on number of operations
select case line_edge 'Cater for right and left side limits situations when not all of the line is seen ...
case 1 : line_pos = line_centre '... line dissapearing on the left side ...
case 15 : line_pos = 15 - line_centre '... line dissapearing on the right side ...
else : line_pos = line_edge - line_centre '... both edges inside field of view
endselect
select case line_pos 'Maybe can be done faster, but takes us as it is
case 1 to 7 : Eline = -8 + line_pos 'Set negative Eline from line_pos
case 9 to 15 : Eline = line_pos - 8 'Set positive Eline from line_pos
else : ELine = 0 'Set error to zero
endselect
#endmacro
