​ ​ ​ ​ My 1st line follower
Results 1 to 4 of 4
Thread: My 1st line follower
  1. #1
    Join Date
    Sep 2016
    Location
    United Kingdom
    Posts
    735
    Default My 1st line follower
    By popular demand..well erco
    I think it's been done before. A simple line follower...well there's different ways and I tried a 6 sensor array and it's pee poor but almost funny to watch.
    OK the array http://www.hobbytronics.co.uk/qtr-8r...IgkaAlOa8P8HAQ
    Well I tried the "time capacitor discharge" method but used erco's "quick and dirty method"
    The continuous servos don't really work slow,that's my excuse.
    https://youtu.be/txIOZrravKg https://www.youtube.com/watch?v=3E7wK7x8IBc
    Oh,the code I'm playing with
    ;6 sensor,dual continuous servo line follower
    #picaxe 20m2
    setfreq m4
    symbol lservo=b.6
    symbol rservo=b.7
    symbol reflec=w0
    servo lservo,134 ;default speed
    servo rservo,166
    reflec=pinsb
    ;if reflec=33 then servopos lservo,134:servopos rservo,166:pause 200:endif:goto main ;sensor 2 and 5-must be junction-keep going forward straight
    if reflec=3 or reflec=1 or reflec=2 then servopos lservo,100:servopos rservo,154:goto main:endif ;left fastest,right slowest
    if reflec=6 or reflec=4 then servopos lservo,120:servopos rservo,158:goto main:endif ;left faster,right slower
    if reflec=4 then servopos lservo,132:servopos rservo,168:goto main:endif
    if reflec=12 then servopos lservo,134:servopos rservo,166:goto main:endif ;same
    if reflec=8 then servopos lservo,136:servopos rservo,164:goto main:endif
    if reflec=24 or reflec=16 then servopos lservo,142:servopos rservo,180:goto main:endif ;right faster,left lower
    if reflec=48 or reflec=32 or reflec=16 then servopos lservo,146:servopos rservo,200:goto main:endif ;right fastest,left slowest
    ;servopos lservo,134:servopos rservo,166:goto main ; no pins lit
  2. #2
    Join Date
    Sep 2016
    Location
    United Kingdom
    Posts
    735
    Default
    The usual photos,heath rob,tyres swapped. The sensor is fussy about height. The track was paint not uniform tape so calibrating was silly. Still..SAM_1400.JPGSAM_1401.JPG
  3. #3
    Join Date
    Jul 2011
    Location
    Los Angeles, CA
    Posts
    1,990
    Default
    Just beautiful, stan74! Thanks for posting more info here. Plywood is a great chassis material. Cheap, strong, stiff, commonly available, and easy to cut.
    Chassis geometry is a huge factor. Your sensors are very close to your wheel axis. If you move your sensor forward (or wheels back) you would sense and maneuver very differently. Might be better, might not, depending on the course. Only experimenting will tell.
    Definitely your first line follower, but not your last!
  4. #4
    Join Date
    Sep 2016
    Location
    United Kingdom
    Posts
    735
    Default
    To me it's fun..I do have other leejure activities but this is cheap in the winter. brrrr. Get a working chassis and your off. The same as turning leds on and off but with more imagination. Picaxe is suited for robot stuff. Top!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
