This is new to me, but obviously RevEd planned for it.
The command, TABLECOPY allows you to move table data to ram. Hundreds of bytes can be moved depending on the picaxe. I used a 14M2, with 512 bytes of ram.
I put 370-some bytes of zero-terminated strings in the table (favorite Shakespeare quotes), moved it to ram, ran through it byte by byte with bptr, saving the starts of the strings (also in ram with POKE Wn, Word Wn starting at byte 28, above the named registers), and then every 5 seconds randomly chose a string to display with sertxd.
If you run this in the simulator, be patient. It takes about 30 seconds (with the delay time set to 0) to scan the bytes in ram.
Then the strings display.
You can similarly run through the table itself a byte at a time with READTABLE (but a "@tptr" would help). This provides an alternate way.
I found a PE6 bug. If you use "poke wRamAddr, WORD bptr" when bptr > 255, only the least significant byte is saved.
Using this instead works:
wScratch = bptr
poke wRamAddr, WORD wScratch ' save address in ram (and table) of string
Same truncation occurs with "peek wRamAddr, WORD bptr".
bptr otherwise can contain values up to 511.
[If a large table, for instance for messages, is prepared by an external program, it might be better for that program also to make code for the starts of the strings.]
' 14tabletrick.bas prints random lines from a table
#picaxe 14M2
#terminal 4800
table 80,("'Tis time to fear when tyrants s")
table 112,("eem to kiss",0)
table 124,("Some innocents 'scape not the th")
table 156,("underbolt",0)
table 166,("A friendly eye could never see s")
table 198,("uch faults",0)
table 209,("Ripeness is all",0)
table 225,("How poor are they that have not ")
table 257,("patience",0)
table 266,("Everything that grows holds in p")
table 298,("erfection but a little moment",0)
table 328,("One sorrow never comes but bring")
table 360,("s an heir",0)
table 370,("Have more than thou showest; spe")
table 402,("ak less than thou knowest; lend ")
table 434,("less than thou owest",0)
table 455,(0)
symbol cRamStart = 28
symbol cTableStart = 80
symbol cTableLen = 456-cTableStart
symbol cMaxRamAddr = 511
symbol cwRandomValue = 48611 ' seed with large prime number
symbol stringCount = b4 ' number of 0-delimited strings
symbol stringNo = b5 ' number of string to be displayed
symbol priorString = b6
symbol wScratch = w12
symbol wRamAddr = w13
symbol wRand = s_w1
tablecopy 80,cTableLen
wRamAddr = cRamStart
bptr = cTableStart
wRamAddr = wRamAddr + 2
stringCount = 0
inc bptr
do while @bptrinc <> 0 and bptr < cMaxRamAddr
if @bptr = 0 then
inc bptr
wScratch = bptr
' poke wRamAddr, WORD bptr ' save address in ram (and table) of string; failed with bptr wrap
inc stringCount
sertxd(#stringCount," strings found",cr,lf)
wRand = cwRandomValue
random wRand
stringNo = wRand // stringCount
wRand = wRand * time
if stringNo <> priorString then ' don't repeat
priorString = stringNo
wRamAddr = stringNo * 2 + cRamStart ' address in ram of address of string in ram or table
peek wRamAddr, WORD wScratch
bptr = wScratch
sertxd(@bptrinc)
if @bptr = 0 then
sertxd(cr,lf)
exit
pause 5000
wScratch = bptr
