​ ​ ​ ​ GPS Module PPS accuracy?
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: GPS Module PPS accuracy?
  1. #1
    Join Date
    Oct 2009
    Location
    Staffs, UK
    Posts
    212
    Default GPS Module PPS accuracy?
    I see quite a few clock designs use the PPS output from a GPS module (VK15E module in stock) to replace the crystal timebase when a GPS signal is available. I'm looking for a stable accurate 1Hz signal as part of a Picaxe based clock timer but trying to decoding anything else from the module is way beyond me!
    Read varying reports and data sheets I've found but dont seem to cover it. Question is anyone know how accurate and stable is the PPS output?
    Thanks
  2. #2
    Join Date
    Feb 2011
    Location
    Cardiff,UK
    Posts
    4,204
    Picaxe in Space is now Silent (but probably still running)
    http://www.50dollarsat.info/
  3. #3
    Join Date
    Oct 2012
    Location
    USA
    Posts
    464
    Default
    Or you could just use the time from the module, I posted a simple gps clock code here recently.
  4. #4
    Join Date
    Oct 2009
    Location
    Staffs, UK
    Posts
    212
    Default
    Thanks for the links, very useful, lots of issues raised but it looks like other folks use the PPS for serious work in spite of evidence of jitter.
    The clock code is interesting but I think I'll try the 1Hz output first as it should do what I want. I was going to put it through a schmitt trigger before I use it. Put a scope on the output and the pulse is 200ms high and 800ms low, exactly what I want, great start!
  5. #5
    Join Date
    Feb 2011
    Location
    Cardiff,UK
    Posts
    4,204
    Default
    I found the link by doing a Google Search on 'GPS Module PPS accuracy'
  6. #6
    Join Date
    Feb 2012
    Location
    London
    Posts
    2,871
    Default
    Quote Originally Posted by Pongo View Post
    It rather depends if you want to make a very high accuracy "short term" measurement, or know the "Absolute Time" very precisely. The ASCII strings from a GPS engine/microcontroller are not likely to be very good for short-term measurements.
    However, the GPS system is fundamentally much more "accurate" than the rotation of the Earth, to the extent that I believe that "GPS Time" is around 10 seconds ahead of GMT or UTC. Presumably any commercial GPS engine corrects for that in calculating its data stream.
    But if you have a project to land on Mars it's worth checking whether your calculations are in Metric or Imperial units, or when developing a much higher-powered rocket launcher that an integer calculation doesn't overflow.
  7. #7
    Join Date
    Oct 2012
    Location
    USA
    Posts
    464
    Default
    From the Mildy Interesting Department: VisualGPS sells software that conditions a PC clock to GPS time. Good if you are running a seismometer or similar instrument.
  8. #8
    Join Date
    Oct 2013
    Location
    Stockport, UK. On a good day, Cornwall UK
    Posts
    474
    Default
    Quote Originally Posted by AllyCat View Post
    When I got my first Garmin, back in 2006 ish - you could see that the clock was different to that obtained from other accurate sources. I seem to recall an error as high as 13 seconds.
    However, commercial units don't seem to exhibit this behaviour these days, so presumably they must (somehow) be allowing for it now.
  9. #9
    Join Date
    Nov 2014
    Location
    Planet Earth
    Posts
    394
    Default
    Quote Originally Posted by JPB33 View Post
    Thanks
    The gps.gov webpage and specifications gives pps accuracy as '1. The normal operations performance standards are consistent with a Block II/IIA clock stability of 1x10-11 at a tau of 3 seconds for either Rubidium clocks or Cesium clocks.' which you can take as very very accurate or in normal parlance 0.1ppb, by comparison a normal xtal is about 10ppm not bilion. I didn't look through all of the (huge) specification but I'm sure they cover jitter, my guess is it will tend to zero.
  10. #10
    Join Date
    Feb 2012
    Location
    London
    Posts
    2,871
    Default
    Quote Originally Posted by PhilHornby View Post
    .. commercial units don't seem to exhibit this behaviour these days, so presumably they must (somehow) be allowing for it now.
    I wasn't aware of the issue with my first Garmin (GPS45), back around 1994, but a quick Google produced the following from here.
    "GPS time was set to match UTC in 1980, but has since diverged. The lack of corrections means that GPS time remains at a constant offset with International Atomic Time (TAI) (TAI – GPS = 19 seconds). Periodic corrections are performed to the on-board clocks to keep them synchronized with ground clocks.
    The GPS navigation message includes the difference between GPS time and UTC. As of July 2015, GPS time is 17 seconds ahead of UTC because of the leap second added to UTC June 30, 2015. Receivers subtract this offset from GPS time to calculate UTC and specific timezone values. New GPS units may not show the correct UTC time until after receiving the UTC offset message. The GPS-UTC offset field can accommodate 255 leap seconds (eight bits).
    GPS time is theoretically accurate to about 14 nanoseconds. However, most receivers lose accuracy in the interpretation of the signals and are only accurate to 100 nanoseconds."
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
