​ ​ ​ ​ Help with push-button to change LED flash pattern
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: Help with push-button to change LED flash pattern
  1. #1
    Join Date
    Aug 2015
    Location
    Edmonton Alberta
    Posts
    5
    Default Help with push-button to change LED flash pattern
    Hi all,
    I have learned a lot from the people here. To-day I am asking for some help with my program. Been working with it since July 2015.
    I want a push button to be detected immediately to change a LED flash sequence.
    Manual 3 says SETINT is polled between program lines. I thought that would get it done.
    As written the program will leave flash1 and proceed to flash2 but will not leave flash2.
    The program is below. An experienced eye is appreciated.
    Thank you for your help.
    David
    Code
    '08M2 FBI style LED strobing_Jul_26_2015_1007.bas
    'Program by David Beatty @ Edmonton, Alberta
    'inspired by a Youtube video https://www.youtube.com/watch?v=tQoZCix_1mY
    'Labelled RC car flasher (FBI style) by Vicsys, http://vicsys.hu
    #Picaxe 08M2
    #no_data
    setint %00010000,%00010000            'button on C.4'
    pinC.4 = b1                        'declare button on C.4
    b1 = 0                        'initialize b1'
    Interrupt:                        'used to get an imediate button response
            high C.0: high C.1        'turn 'em all on to show flash sequence change
            pause 1000                'time to see the button push was detected
            b1 = b1 + 1                'cause the program to select the next flash sequence
            if b1 = 1 then flash1         'array of flash sequences
            if b1 = 2 then flash2
            if b1 = 3 then flash3
            if b1 = 4 then flash4
            if b1 = 5 then flash5
            if b1 = 6 then flash6
            if b1 = 7 then flash7
            if b1 = 8 then flash8
            if b1 > 8 then flash1
            setint %00010000,%00010000    'resets the setint for the next button push
                                'flash sequence catalogue
    flash1:
            high C.0: high C.1        'all on for area illumination
    flash2:
            pulsout C.0, 255: pulsout C.1,255    'simultaneous flash of both LEDs
            pause 150
            pulsout C.0,255: pulsout C.1,255
    flash3:                            'LEDs both pulse 3X, wait 1 sec. - loop
            high C.0, C.1
            pause 100
            low C.0, C.1
            pause 100
            high C.0, C.1
            pause 100
            low C.0, C.1
            pause 100
            high C.0, C.1
            pause 100
            low C.0, C.1
            pause 600
    flash4:                            'LED right pulses 2X then LED left pulses 2X loop
            pulsout C.0, 255:pause 60: pulsout C.0,255 pause 400
            pulsout C.1, 255:pause 60: pulsout C.1,255 pause 400
    flash5:                            'LED right pulses 2X and remains high while LED left pulses 2X and remains high -                                 loop
            pulsout C.0,150
            pause    80
            high C.0
            pause 30
            low C.0
            Pulsout C.1,150
            pause 80
            high C.1
            pause 30
            low C.1
            pause 30
    flash6:                            'LED right pulses 2X pausing while LED left pulses 2X and pauses, loop
            pulsout C.0,255
            pause 100
            pulsout C.0,255
            pause 100
            pulsout C.1,255
            pause 100
            pulsout C.1,255
            pause 125
    flash7:                            ' wig wag pattern
            pulsout C.0,255
            pause 100
            pulsout C.1,255
            pause 100
            pulsout C.0,255
            pause 100
            pulsout C.1,255
            pause 100
            pulsout C.0,255
            pause 100
            pulsout C.0,255
            pause 100
            pulsout C.1,255
            pause 100
            pulsout C.1,255
            pause 100
            pulsout C.0,255
            pause 100
            pulsout C.1,255
            pause 100
            pulsout C.0,255
            pause 100
            pulsout C.1,255
            pause 100
    flash8:                            'alternating wig wag pattern
            pulsout C.0,255
            pause 100
            high C.0
            pause 170
            low C.0
            pause 600
            pulsout C.1,255
            pause 100
            high C.1
            pause 170
            low C.1
            pause 600
  2. #2
    Join Date
    Feb 2010
    Location
    Don't Mess With My Texas!
    Posts
    2,523
    Blog Entries
    7
    Default
    Define what you mean by "... to be detected immediately ...."
    You probably don't need an Interrupt routine. Just keep the detection of "button on C.4" in a tight loop.
    - Tex
    __________________________________________________ _______________________
    These words are my opinion, WYLION. Any resemblance to truth or fiction is accidental at best.
    "Truth lies dormant in our future history." ― Tex Clodhopper LXVI
    "Confidence is ignorance. If you're feeling cocky, it's because there's something you don't know." ― Eoin Colfer, Artemis Fowl
  3. #3
    Join Date
    Jan 1970
    Location
    UK
    Posts
    24,221
    Default
    There was an almost similar question a couple of weeks ago for which I provided a solution. Don't have time to search for which thread it was at present but it's there somewhere.
  4. #4
    Join Date
    Feb 2010
    Location
    Posts
    2,523
    Blog Entries
    7
    Default
    Perhaps this post contains the information that Hippy suggested.
    http://www.picaxeforum.co.uk/showthr...ple-Interrupts
    - Tex
  5. #5
    Join Date
    Feb 2009
    Location
    Cheshire, England
    Posts
    2,468
    Blog Entries
    4
    Default
    When your interrupt routine runs, work out on paper what happens. The simulator is no use here.
    The sequence you have is :
    Interrupt triggered, inc b1, goto selected flash routine, loop forever in that routine.
    You never reach the code that re-enables the interrupt.
    Solution : In the interrupt inc b1, then return. In the main loop do the if/then stuff.
  6. #6
    Join Date
    Jan 1970
    Location
    UK
    Posts
    24,221
    Default
    Quote Originally Posted by Texasclodhopper View Post
    That's the one and many thanks for tracking it down.
    But while I was away I realised there's an easier way. Simply RESET and start the program again, jump to whatever routine one now wants to run.
    Of course, the problem there is that 'everything' is zeroed or re-initialised on RESET, and one doesn't like to wear EEPROM out ( and it may be being used for something else anyway ), so how can a number indicating what to do next be preserved through RESET ... ?
    http://www.picaxeforum.co.uk/showthr...-RESET-command
  7. #7
    Join Date
    Feb 2010
    Location
    Posts
    2,523
    Blog Entries
    7
    Default
    I forgot how slick that RESET save idea is.
    dbeatty, only one program, but switch the variable values and save them with Hippy's RESET save idea, then RESET to run your program with the new values.
    Slick!
    - Tex
  8. #8
    Join Date
    Aug 2015
    Location
    Edmonton Alberta
    Posts
    5
    Default
    Thanks everyone.
    Texasclodhopper I had one variation of the program which included a goto in eacg of the flash1 to flash8 sequences. I had to hit the button at the right moment while the subroutine was running to get a response. I tried Start: routines for a parallel program to catch the button press, that didn't work. Now I tried the setinit as the pin is polled between program lines to catch the button push.
    As can be seen in the youtube video the original programmer is able to change flash sequences on demand.
    I'll read the help offered above and pitch it against what I'm after.
    Cheers
    David
  9. #9
    Default
    Hi dbeatty,
    merry Christmas and welcome to the forum.
    I didn't look at the video just modded your code abit
    I think its what your trying to do hopefully should be enough to get you rolling !
    #Picaxe 08M2
    #no_data
        'Starts in OFF STATE                        'flash sequence catalogue
    flash1:
         if b1 = 1 then
        goto flash1 :endif
    flash2:
        low C.0, C.1
        if b1 = 2 then
            pause 150
        goto flash2 :endif
        if b1 = 3 then
            high C.0, C.1
            pause 100
            low C.0, C.1
            pause 100
            high C.0, C.1
            pause 100
            low C.0, C.1
            pause 100
            high C.0, C.1
            pause 100
            low C.0, C.1
            pause 600
        goto flash3 :endif
        if b1 = 4 then
        goto flash4 :endif
        if b1 = 5 then
            pulsout C.0,150
            pause    80
            high C.0
            pause 30
            low C.0
            Pulsout C.1,150
            pause 80
            high C.1
            pause 30
            low C.1
            pause 30
        goto flash5 :endif
        if b1 = 6 then
            pulsout C.0,255
            pause 100
            pulsout C.0,255
            pause 100
            pulsout C.1,255
            pause 100
            pulsout C.1,255
            pause 125
        goto flash6 :endif
        if b1 = 7 then
            pulsout C.0,255
            pause 100
            pulsout C.1,255
            pause 100
            pulsout C.0,255
            pause 100
            pulsout C.1,255
            pause 100
            pulsout C.0,255
            pause 100
            pulsout C.0,255
            pause 100
            pulsout C.1,255
            pause 100
            pulsout C.1,255
            pause 100
            pulsout C.0,255
            pause 100
            pulsout C.1,255
            pause 100
            pulsout C.0,255
            pause 100
            pulsout C.1,255
            pause 100
        goto flash7 :endif
        if b1 = 8 then
            pulsout C.0,255
            pause 100
            high C.0
            pause 170
            low C.0
            pause 600
            pulsout C.1,255
            pause 100
            high C.1
            pause 170
            low C.1
            pause 600
        goto flash8 :endif
              do while pinc.4=1 loop
             inc b1                'cause the program to select the next flash sequence
            if b1 > 8 then : b1=0 :endif
  10. #10
    Join Date
    Aug 2015
    Location
    Edmonton Alberta
    Posts
    5
    Default
    Thanks so much for your time and effort. I'll give it some time.
    Merry Christmas to you and yours.
    David
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
