Nested macroes
In a program written in PE6, this sequence :
#IFDEF test
sertxd(" %",msg,13,10)
#ENDIF
is often repeated, so I would like to put it in a macro. However, this doesn't work:
#macro println(msg)
#IFDEF test
#ENDIF
#endmacro
Is there a way to define such a macro in PE6?
The way precedence of directives is handled it is currently not possible. The best you can do is ...
#macro println(msg)
#endmacro
#IFDEF test
println( ...... )
#ENDIF
irskir
What I really really want to do is :
#macro turnOnRedLed
#ifdef PCBoardVersion1
low LEDRed
#else
high LEDRed
#endif
#endmacro
Can't see any way to do this except to call a subroutine each time which takes much more code space, or of course clutter the program with this pattern over and over and hope they are all correct. This, and the #rem instructions inside a #ifdef construct makes going to version 6 useless. At least 5 could do the latter.
stan74
macros are a waste of space especially when they nest,usually late spring. I end up de-macroing other peoples code. Don't do it.It's not big or clever.
edmunds
I agree to some extend as the code gets very difficult to debug in simulator. And re-writing back and forth to subroutines introduces errors on top of the ones you already have. However, gosubs are painfully slow. If you need speed, there is not a thing like a macro. Also, a thing I have not mastered fully, but see good code every now and then is passing parameters to a macros. Because picaxe basic lacks functions with parameters, this can sometimes be very useful when writing complex code.
Edmunds
stan74
I'm not sold on using macros. I don't want to re-iterate a discussion but can't see the difference from a gosub except it looks neater to some people.What controller time and memory does it save and I'll use macros.
This doesn't look basicy
#macro turnOnRedLed
low LEDRed
#else
high LEDRed
#endif
#endmacro
Macros are often used with a gosub, not instead of. Here are a couple from our Sphero example:
#MACRO SetRgbColor(R, G, B)
   b0 = R
   b1 = G
   b2 = B
   gosub SendRGB
#ENDMACRO
#DEFINE SetHeading(H) w0 = H : Gosub SendHeading
#MACRO SetHeadingSpeed(H, S)
   w1 = H
   b0 = S
   gosub SendHeadingSpeed
#ENDMACRO
AllyCat
1. What controller time and memory does it save and I'll use macros.
2. This doesn't look basicy
1. About 3,200 fewer PIC instruction cycles for each CALL !
2. Looks like fairly basic preprocessor stuff to me. Does this do what was required?
[color=Navy]#ifdef [/color][color=Black]PCBoardVersion1[/color]
[color=Navy]#define [/color][color=Black]turnon [/color][color=Blue]low[/color]
[color=Navy]#else
#define [/color][color=Black]turnon [/color][color=Blue]high[/color]
[color=Navy]#endif
#macro [/color][color=Black]turnOnRedLed
turnon LEDRed[/color]
[color=Navy]#endmacro[/color]
But I must admit, that's not enough to make me use PE6 routinely in place of PE5. ;)
stan74
pe5 doesn't compile stuff that pe6 does,same code,setup etc.
"1. About 3,200 fewer PIC instruction cycles for each CALL !"
ok Alan, I'll post some code in a new thread and someone can macro it and show it as an example of cool coding if that's safe.
This didn't compile in pe5.
[color=Navy]#picaxe [/color][color=Black]28x2[/color]
[color=Blue]setfreq m16
pwmout pwmdiv4[/color][color=Black], [/color][color=Blue]B.0[/color][color=Black], [/color][color=Navy]99[/color][color=Black], [/color][color=Navy]399 [/color][color=Green]; 10000Hz at 100% @ 16MHz[/color]
[color=Blue]pwmout pwmdiv4[/color][color=Black], [/color][color=Blue]B.5[/color][color=Black], [/color][color=Navy]99[/color][color=Black], [/color][color=Navy]399 [/color][color=Green]; 10000Hz at 100% @ 16MHz[/color]
[color=Black]main:[/color]
[color=Blue]pwmduty b.0[/color][color=Black],[/color][color=Navy]0[/color]
[color=Blue]pwmduty b.5[/color][color=Black],[/color][color=Navy]0[/color]
[color=Blue]pause [/color][color=Navy]300[/color]
[color=Blue]pwmduty b.0[/color][color=Black],[/color][color=Navy]399[/color]
[color=Blue]pwmduty b.5[/color][color=Black],[/color][color=Navy]399[/color]
[color=Green];for w0=0 to 399
;;pwmout b.0, 39, 160
;pwmduty b.0,w0
;;pwmout b.5, 39, 160
;pwmduty b.5,w0
;;sertxd (#w0,cr,lf)
;;pause 1000
;next w0
;pause 200[/color]
[color=Blue]goto [/color][color=Black]main[/color]
pe6 worked in win 10 until I installed some versions of basic. Maybe the .bas file extension.
stan74
next time or I can vex it I'll post code.I didn't imagine it,happens a lot. It's so dos looking,text n all. Where's the error,find it yourself.
I re-read the manual to see what works in m2 and x2 and think apart from physical size,if you get 1 picaxe,make it a 28x2,it seems to have the best hardware. the start1 m2 option wasn't worth the bother for me and things like // and other "special" functions don't work. 1k ram is nice to play with to and plenty of pins. 2 separate pwm,b.0 and b.5 and servo at the same time but not sure about that,didn't work for me..try again.
