Error in Blockly set pinsB
Technoman
PE6 6.0.8.11 - 28X1
give an error message, because let pinsB is not known
Converted blocks :
Is it a bug?
It looks like the "pinsB" Blockly uses has not been aliased to the "pins" which the 28X1 compiler expects. We will look into it and get that fixed.
Technoman
Thank you for this quick answer.
Unfortunately, the guys in charge of computer maintenance just install the new image on every HDD today. I'm afraid we are stuck with 6.0.8.11 for a year.
Technoman
The block "Set pwmout ..." is also affected for the same reason.
A workaround : 'symbol C.1 = 1' and 'symbol C.2 = 2'
The block "Set pwmout ..." is also affected for the same reason.'
That appears to be working for me and I thought that was the case when we were looking into the pinsB issue. It could be that I was on a version which had not been released so already fixed.
