Random Servo Movement
Joecolo
Please Help! I would like to move a servo randomly within a small parameter. I tried this but I get larger movements than 150 to 145, what am I doing wrong?
Thanks Joe
start:
servo 2,55
servopos 2,150
Random w0
w1 = w0 // 150 + 145
servo 2,55
servopos 2,w1
goto start
stan74
let w0=timer
start:
random w0
if b0>200 then let b0=200:endif
if b0<100 then let b0=100:endif
servopos 2,b0
pause 100
goto start
maybe
Joecolo
The program doesn't like timer? hmmmm
let w0 = Timer
Syntax error on line 3 at/before position 9
Error: Unknown symbol - Timer
erco
Did you want it to jerk from position to position or move smoothly?
Re: your original program, that second servo 2,55 is causing unnecessary roughness.
Untested mod to your program:
w0=time
servo 2,150
start:
Random w0
w1 = w0 // 150 + 75
sertxd (#w1,13,10)
servopos 2,w1
goto start
Joecolo
Erco
In a perfect world if I could get movement like this
servo 2,55
for b1 = 55 to 60
servopos 2,b1
pause 30
next b1
but small random positions
What is "sertxd (#w1,13,10)" ?
I tried your code but the movement was too great and exceed the servos range, how do I fine tune this?
Thanks Joe
In the line:
W1 = w0 // 150 + 145
The first part (w0 // 150) with give a value in the range 0 to 149.
Then you are adding the base value of 145 thus then entire range is 145 to 294.
If you only want the small/narrow range 145 to 150 then use
W1 = w0 // 6 + 145
Next remove the line:
Servo 2,55
From within the loop
erco
Joe: Servos often have extreme limits of 75 to 225, 150 being center. Figure out the range of values you want, min and max, by experimentation. Then use this formula in your program:
w1=w0//(max-min)+min
Joecolo
erco
this one is working, I have a narrow range of random movement between 150 and 165 using "w1 = w0 // 15+150"
w0=time
servo 2,150
start:
Random w0
w1 = w0 // 15+150
sertxd (#w1,13,10)
servopos 2,w1
goto start
and thank you for "sertxd (#w1,13,10)", I didn't know this was an option, 152
155
161
158
152
154
159
153
156
162
159
154
158
152
155
stan74
What's the servo connected to, curious. Sertxd ("variable= ",#variable,cr,lf) is less mysterious. I'm a newbie.
erco
@Joe:
Glad to hear that's working for you. 15 "servo" units isn't very much travel in the servo world, you either have a very sensitive mechanism or a very long arm!
eggdweather
The servo type makes a huge difference, using a Hitec or Futaba S-bus high resolution digital servo would enable the servo resolution (4096 or 0.03degrees) to exceed the PICAXE resolution.
erco
Aren't digital servos fully backward compatible with analog signals (i.e., the type of signals a Picaxe generates) and programmed to respond just as analog servos would?
stan74
Maybe they remember their position without constant pulses..or maybe not and they just don't use a pot..and they're digital. I bought 2 metal gear not micro servos and the are quieter than micro 9g. Chunky though.
erco
I just got some brand new supposedly digital 9g continuous rotation servos from FiTec to review. Same size, looks & tastes just like regular 9g servos and they work great using a regular analog servo tester. Will advise when I make a video.
