Interrupt 100 times faster in simulator
stan74
Hi,confused again here.I set up code to run a unipolar stepper motor from timer interrupt.It works in the simulator but in pic it runs every 10 seconds.The stepper driver has 4 leds that show the status of the motor inputs and the pin sequence is correct,changing every 10 seconds.
The stepper code works as a subroutine ie motor turns each way. Why is the interrupt not more often? I'm stumped again.Any help welcome.I'm thinking of another hobby.
[color=Green];28x2 A.0 to A3 are unipolar motor pins [/color]
[color=Navy]#picaxe [/color][color=Black]28x2[/color]
[color=Blue]setfreq m16
symbol [/color][color=Purple]posrotor[/color][color=DarkCyan]=[/color][color=Purple]b0[/color][color=Black]:[/color][color=Blue]symbol [/color][color=Purple]direc[/color][color=DarkCyan]=[/color][color=Purple]b1[/color][color=Black]:[/color][color=Blue]symbol [/color][color=Purple]outbyte[/color][color=DarkCyan]=[/color][color=Purple]b2[/color][color=Black]:[/color][color=Blue]symbol [/color][color=Purple]motorspeed[/color][color=DarkCyan]=[/color][color=Purple]b3[/color][color=Black]:[/color][color=Blue]symbol [/color][color=Purple]tempmotorspeed[/color][color=DarkCyan]=[/color][color=Purple]b4[/color]
[color=Blue]let [/color][color=Purple]dirsa[/color][color=DarkCyan]=[/color][color=Navy]%11111111[/color][color=Black]:[/color][color=Blue]let [/color][color=Purple]posrotor[/color][color=DarkCyan]=[/color][color=Navy]1[/color][color=Black]:[/color][color=Blue]let [/color][color=Purple]direc[/color][color=DarkCyan]=[/color][color=Navy]1[/color][color=Black]:[/color][color=Blue]let [/color][color=Purple]motorspeed[/color][color=DarkCyan]=[/color][color=Navy]1[/color][color=Black]:[/color][color=Blue]let [/color][color=Purple]tempmotorspeed[/color][color=DarkCyan]=[/color][color=Purple]motorspeed[/color]
[color=Blue]settimer count [/color][color=Navy]65530    [/color][color=Green]; settimer to count mode[/color]
[color=Blue]settimer t1s_16
gosub [/color][color=Black]interrupt_Enable
main:[/color]
[color=Blue]do[/color]
[color=Green];let direc=1
;pause 2000
;let direc=0
;pause 2000[/color]
[color=Blue]loop
interrupt:
if [/color][color=Purple]tempmotorspeed[/color][color=DarkCyan]>[/color][color=Navy]0 [/color][color=Blue]then dec [/color][color=Purple]tempmotorspeed[/color][color=Black]:[/color][color=Blue]goto [/color][color=Black]interrupt_enable:[/color][color=Blue]endif
[color=Blue]if [/color][color=Purple]direc[/color][color=DarkCyan]=[/color][color=Navy]0 [/color][color=Blue]then inc [/color][color=Purple]posrotor[/color][color=Black]:[/color][color=Blue]if [/color][color=Purple]posrotor[/color][color=DarkCyan]=[/color][color=Navy]8 [/color][color=Blue]then let [/color][color=Purple]posrotor[/color][color=DarkCyan]=[/color][color=Navy]1[/color][color=Black]:[/color][color=Blue]endif
else[/color][color=Black]:[/color][color=Blue]dec [/color][color=Purple]posrotor[/color][color=Black]:[/color][color=Blue]if [/color][color=Purple]posrotor[/color][color=DarkCyan]=[/color][color=Navy]0 [/color][color=Blue]then let [/color][color=Purple]posrotor[/color][color=DarkCyan]=[/color][color=Navy]8[/color][color=Black]:[/color][color=Blue]endif
lookup [/color][color=Purple]posrotor[/color][color=Black],[/color][color=Blue]([/color][color=Navy]0[/color][color=Black],[/color][color=Navy]%00000011[/color][color=Black],[/color][color=Navy]%00000010[/color][color=Black],[/color][color=Navy]%00000110[/color][color=Black],[/color][color=Navy]%00000100[/color][color=Black],[/color][color=Navy]%00001100[/color][color=Black],[/color][color=Navy]%00001000[/color][color=Black],[/color][color=Navy]%00001001[/color][color=Blue])[/color][color=Black],[/color][color=Purple]outbyte
pinsa[/color][color=DarkCyan]=[/color][color=Purple]outbyte[/color]
[color=Black]interrupt_Enable:[/color]
[color=Blue]setintflags [/color][color=Navy]%10000000[/color][color=Black], [/color][color=Navy]%10000000[/color]
[color=Purple]timer[/color][color=DarkCyan]=[/color][color=Navy]65530[/color]
[color=Purple]toflag [/color][color=DarkCyan]= [/color][color=Navy]0[/color]
[color=Blue]return [/color]
When I run the following test code under simulation or on a real PICAXE-28X2 I get an interrupt every 6 seconds as would be expected -
#picaxe 28x2
#Terminal 19200
setfreq m16
settimer t1s_16
gosub interrupt_Enable
interrupt:
  w0 = w0 + 1
  SerTxd( #w0, " ")
interrupt_Enable:
setintflags %10000000, %10000000
timer=65530
toflag = 0
if tempmotorspeed>0 then dec tempmotorspeed
goto interrupt_enable
or
  dec tempmotorspeed
They are two different things and you should use a colon line separator after then (or even better new lines) to make sure both humans and the compiler understand you correctly.
  dec tempmotorspeed
end if
stan74
Not a chance, Pal!
I'll let others help out here, since I've never used an interrupt.
So how do YOU use stepper motors... or do you use high geared easy peasey dc motors :) The tank dual motors at 220:1 are carp..and it took an hour to build with "instructions". The stepper motor moves tidy..torky but needing 1 of 7 patterns to 4 pins for one motor..can use the other unused transistors on the driver chip to make not gates to drive the lines ie use only 2 lines...but only for 4 waves..not 7..ie different 1/2 wave or summat, totally new moi,erste stepper experiment,didn't have this when I woz in skool.
All the joys of a pic in an easy to use format that doesn't have negative numbers.Even sincliar zx besic had that.
You have probably seen the goody bag of arduino sensors on ebay,not enough hours to play with them all.3 axis inertia sensor needs minus numbers so don't get one,same oled ,needs minus numbers to make line draw algorithm to work...I tried sooooo hard. Why don't I use my RPi's to make a robot??? r u on facebook erco?
erco
Transistors? You do know about the world's cheapest steppers & ULN2003 drivers on Ebay?
http://www.ebay.com/itm/ULN2003-chip-Module-Stepper-Motor-Driver-Board-Test-Board-For-Arduino-Mega-NEW-/332039552989
http://www.ebay.com/itm/ULN2003-ULN2003AN-Stepper-Motor-Driver-Board-Module-for-28BYJ-48-5V-12V-Arduino-/262130708059
http://www.ebay.com/itm/5V-28BYJ-48-Stepper-Motor-Driver-Test-Module-Board-with-ULN2003-Chip-Set-Hotsale-/371742138940
Using/mastering steppers is a rite of passage for budding roboticists. That stepper above is cheap but frustrating. Skips steps easily and the oddball gear ratio makes it very difficult to get precision. And in general, steppers needs of I/O pins or a dedicated controller chip. Here are my few stepper projects;
https://www.youtube.com/watch?v=SYi0Cs8jJqM
https://www.youtube.com/watch?v=TLdkKKMfUP0
https://www.youtube.com/watch?v=sogHSr37BsE
stan74
I'll check that out technical. I just wrote it short. What I want is the interrupt to happen say every few mS,enough to move the stepper while the main prog does stuff.My first use of a stepper motor..the 1/2 wave-4 pattern has no torque.
I could use a gosub to move the motor but it's pure slow in a do:gosub move:loop,so not an option in a prog that does much.
As an option I tried start0 and start1 to hold the motor code...but to no avail.least I tried.
erco
Check out stepper motor full step, half step & wave drive patterns: https://en.wikipedia.org/wiki/Stepper_motor
No shame in driving a 5V stepper with 9-12 volts to improve speed/torque, it's quite common. Just switch fast, keep moving and don't leave the coils on very long. Turn everything OFF as soon as you stop.
stan74
Far out man..or dude.I guess you think steppers are ok a bit,kinda like a continuous stepper...but "a bit harder :)"
I'm ebayed out a bit for now,sharp IR sensors soon as well.Making a tank bot for grandson with carp tamiya.SAM_1177.JPG
erco
Nice looking tank bot. Reminds me of one I built with those parts, 4 different configurations.
stan74
#picaxe 28x2
#Terminal 19200
setfreq m16
settimer t1s_16
interrupt:
  w0 = w0 + 1
  SerTxd( #w0, " ")
interrupt_Enable:
timer=65530
toflag = 0
I'm assuming I pre-load timer with how many 40uS whatever ticks < 65535 and the interrupt happens and then it is retriggered with the code at the end of the interrupt.So timer=65530 is 6 x 40us ticks, but it's not.Please could you give interrupt code that goes to interrupt every 200 us.. if that would run a uni polar stepper motor. First time I've used the simulator.
stan74
Yeah. Want the tracks not too tight/not too slack or the links bend.Something that works on a table.Mine start in the living room and end up wandering around the kitchen.They come back sometimes. My kit came with enough cogs,axles and track to make 2 tank bots.
Bots looking like Wall-E which is a waste of track but more aesthetically pleasing (cooler), a us ranger is better vertical with the mic at the bottom.Need clear acrylic/perspex recycle not buy 6 foot x 2 foot sheet..too mean and recycling is safe.
stan74
or
  dec tempmotorspeed
  dec tempmotorspeed
end if
This is the same but more readable.Still slowww and changed to use parallel programming but does nothing.
[color=Blue]start0:
do[/color]
;pause 2000
;let direc=0
;pause 2000[/color]
[color=Blue]loop
start1:
if [/color][color=Purple]tempmotorspeed[/color][color=DarkCyan]=[/color][color=Navy]0 [/color][color=Blue]then
      [/color][color=Blue]goto [/color][color=Black]start1[/color]
[color=Blue]endif
      [/color][color=Blue]if [/color][color=Purple]posrotor[/color][color=DarkCyan]>[/color][color=Navy]8 [/color][color=Blue]then
      [/color][color=Blue]if [/color][color=Purple]posrotor[/color][color=DarkCyan]<[/color][color=Navy]1 [/color][color=Blue]then
stan74
If I can't solve this I've a 20x2 I could use as a slave.A lot of bother or just go forward one wheel rotation and scan and manoeuvre..yawn.I like them a bit more dynamic like this which can see both directions so doesn't get caught out. Like bot 1, rangefinder scans and moves each program loop.SAM_1186.JPG
You need to use a different technique with X2 chips. The "parallel" programming technique is only possible on M2-series PICAXEs.
Edit: Persist with your original code. See next post.
gosub [/color][color=Black]interrupt_Enable[/color]
The timer can only be configured one way. SetTimer Count <value> is expecting to count pulses on Pin C.0 (the manual is not very clear on this). Alternatively, SetTimer t1s_16 will tick once every second with 16MHz clock. Since this command is last in the startup, this mode prevails.
You initialise the timer's rollover value in your interrupt enable routine to 65530. The first interrupt will occur once every 65536 - 65530 or 6 seconds. That will be slow!
Depending on how often interrupts are occurring, the TOFlag should be reset promptly on entering the interrupt routine and the SetIntFlags should the very last command to be executed before exiting.
There are two parts to the timer. There is an internal counter and "SETTIMER value" determines how quickly this counter exceeds its maximum. When the counter exceeds its maximum it will increment the 'timer' variable. When the 'timer' variable exceeds its maximum the interrupt will occur.
"SETTIMER t1_16" means increment the counter at a rate that it exceeds its maximum every second. 'timer' is therefore incremented every second'. 'timer' starts at 65530 so it requires counter exceeding its maximum six times before the interrupt occurs.
At 16MHz the counter increments every 16us. 200/16 = 12, 65536-12 = 65524 ...
[b]SetTimer 65524[/b]
Gosub Interrupt_Enable
Do
Loop
Interrupt:
Interrupt_Enable:
  SetIntFlags %10000000, %10000000
  [b]timer = 65535[/b]
  toFlag = 0
  Return
That is untested and it can be difficult to tweak fast interrupts to get the timing right.
stan74
I think a timer interrupt can only be every 1 second or longer. I read assembler is interpreted. Could a real Interrupt beset up? I could code it.
Any road, I set up 1KHz pwm on pin B.0 and connected B.0 to B.7 via 1 K resistor and set up hardware interrupt to trigger on B.7 high.
It works and the motor is turning flat out I reckon. Problem is the main program loop is hardly ever serviced. I found the same when I used 2 slotted decoder wheels.Oh well, it was an interesting few hours. Here's my code for unipolar people, hope it's useful.
[color=Blue]pwmout pwmdiv16[/color][color=Black], [/color][color=Blue]B.0[/color][color=Black], [/color][color=Navy]249[/color][color=Black], [/color][color=Navy]499 [/color][color=Green]; 1KHz out on B.0[/color]
[color=Blue]pwmduty B.0[/color][color=Black],[/color][color=Navy]499[/color]
[color=Blue]setint [/color][color=Navy]%10000000[/color][color=Black],[/color][color=Navy]%10000000[/color][color=Black],B [/color][color=Green]; B.7 gets pwm pulses from B.0[/color]
[color=Blue]gosub [/color][color=Black]interrupt_Enable [/color][color=Green];------ and triggers an interrupt to move motor[/color]
[color=Black]main:[/color][color=Green]; stick any code here[/color]
;pause 2000
;let direc=0
;pause 2000[/color]
[color=Blue]loop
interrupt:[/color][color=Green]; motor is taken care of,happy days[/color]
[color=Blue]if [/color][color=Purple]tempmotorspeed[/color][color=DarkCyan]=[/color][color=Navy]0 [/color][color=Blue]then
      [/color][color=Blue]goto [/color][color=Black]interrupt_enable[/color]
[color=Blue]endif
[color=Blue]setint [/color][color=Navy]%10000000[/color][color=Black],[/color][color=Navy]%10000000[/color][color=Black],B[/color]
[color=Blue]return
      [/color]
No. The following interupts every half a second, increments the displayed count by 10 in every 5 seconds.
I suspect you aren't absorbing what the manual says and how things were described in post 19.
We are going to increment the internal counter (minor tick) every half a second. 500ms = 500000us which, with 1 minor tick every 16us at 16MHz, means we need 500000/16 = 31250 minor ticks per half second. 65536 - 31250 = 34286 which is our SETTIMER preload value.
Every half second our minor tick count will overflow, giving a major tick, incrementing 'timer'. When 'timer' overflows it generates an interrupt so we set it to 65535 so it overflows on the first major tick.
#picaxe 28x2
#terminal 19200
setfreq m16
[b]settimer 34286[/b]
interrupt:
  w0 = w0 + 1
  SerTxd( #w0, " ")
interrupt_Enable:
  toflag = 0
stan74
I can get an interrupt every 1/2 second but I'll stand in the rain for charity if you can post code that runs at 100 Hz. I think that's why the hardware option I've used has been posted.In your code settimer 34286, change to 65534,24,34 still 1 sec, I just tried it, not the stimulator (erco fnarr,fnarr lost in translation),real picaxe. How can 1/2 a second be changed to 1/100th second. I reckon stepper motors should be avoided for a tranquil life.Thanks for your time hippy,much appreciated.
stan74
I have noticed that setting the interrupt to 244hz with setfreq m4 the 4 leds on the driver board were visibly flickering rather than constantly lit suggesting a frequency of < 50Hz so I scoped the pwm and it said 245 Hz.So I tried 500Hz..still flickering.1KHz no flicker.So I scoped the pins C0 to C4 to the motor and they are pulsing at 53Hz. ok the pin might be on 1 in 7 but something's wrong.
See what I meant about steppers?
Take a brolly ... :)
10ms = 10000us
10000/16 = 625
65536 - 625 = 64911
This interrupts and increment the w0 count every 10ms, outputs an asterisk every 100 interrupts, one every second ...
#picaxe 28x2
#terminal 19200
setfreq m16
settimer 64911
interrupt:
  w0 = w0 + 1 // 100
  if w0 = 0 Then
    sertxd( "*" )
  end if
interrupt_Enable:
  timer = 65535
  toflag = 0
For 200Hz ...
5ms = 5000us
5000/16 = 312
65536 - 312 = 65224
And change the //100 to //200
stan74
Gives a * every second.This shows nothing scoping b.6.
settimer [/color][color=Navy]64911[/color]
main:[/color]
[color=Blue]do
interrupt:
for [/color][color=Purple]b10 [/color][color=DarkCyan]=[/color][color=Navy]0 [/color][color=Blue]to [/color][color=Navy]100[/color]
[color=Blue]high b.6
low b.6
next [/color][color=Purple]b10[/color]
[color=Blue]return[/color]
  [/color][color=Blue]setintflags [/color][color=Navy]%10000000[/color][color=Black], [/color][color=Navy]%10000000
  [/color][color=Purple]timer [/color][color=DarkCyan]= [/color][color=Navy]65535
  [/color][color=Purple]toflag [/color][color=DarkCyan]= [/color][color=Navy]0
  [/color][color=Blue]return[/color]
stan74
Pause instead of the for:next and the code does nothing.As is motor turns 1/4 one way then 1/2 the other way, 1/4 then 1/2 and so on???
[color=Blue]pwmout pwmdiv16[/color][color=Black], [/color][color=Blue]B.0[/color][color=Black], [/color][color=Navy]249[/color][color=Black], [/color][color=Navy]499[/color]
[color=Blue]do
setint off
let [/color][color=Black]direc[/color][color=DarkCyan]=[/color][color=Navy]1[/color]
[color=Blue]for [/color][color=Purple]w5 [/color][color=DarkCyan]= [/color][color=Navy]1 [/color][color=Blue]to [/color][color=Navy]1000[/color][color=Black]:[/color][color=Blue]next [/color][color=Purple]w5[/color]
[color=Blue]setint off
let [/color][color=Black]direc[/color][color=DarkCyan]=[/color][color=Navy]0[/color]
[color=Blue]loop[/color]
stan74
I think close this thread,so hippy can get on.It's been interesting.I still believe you can't use a timer interrupt to turn a led on and of fast enough that it looks constantly lit..50Hz. I'll move the motor 100 times,take range finder reading,act or move servo and repeat. The wheel moves 1/3 rpsec and you don't notice 10mS breaks.Thanks all.
Probably because of the RETURN without re-enabling interrupts. Unless you are quick enough to catch the initial pulses out of B.6 on the first interrupt you won't see any.
The following code is based on Stan's code posted in #1. The added code is taken directly from another project that I completed a few years ago.
I have included the flashing of the Yellow led to watch the interrupt routine on the oscilloscope. It flashes faster than these human eyes can detect unless I shake my head back and forth.
[color=Blue]Symbol oYellowLED       [/color][color=DarkCyan]= [/color][color=Blue]C.2
symbol [/color][color=Purple]posrotor         [/color][color=DarkCyan]= [/color][color=Purple]b0[/color]
[color=Blue]symbol [/color][color=Purple]direc            [/color][color=DarkCyan]= [/color][color=Purple]b1[/color]
[color=Blue]symbol [/color][color=Purple]outbyte          [/color][color=DarkCyan]= [/color][color=Purple]b2[/color]
[color=Blue]symbol [/color][color=Purple]motorspeed       [/color][color=DarkCyan]= [/color][color=Purple]b3[/color]
[color=Blue]symbol [/color][color=Purple]tempmotorspeed   [/color][color=DarkCyan]= [/color][color=Purple]b4[/color]
[color=Green]'
'      Misc Constants[/color]
[color=Blue]Symbol False            [/color][color=DarkCyan]= [/color][color=Navy]0[/color]
[color=Blue]Symbol True             [/color][color=DarkCyan]= [/color][color=Navy]1[/color]
[color=Green]'
'      Timer Constants[/color]
[color=Blue]Symbol mskBGTimer       [/color][color=DarkCyan]= [/color][color=Navy]%10000000 [/color][color=Green]'When only the timer is running (normally would have hInt0 & 1 config as well)[/color]
[color=Blue]Symbol flgBGTimer       [/color][color=DarkCyan]= [/color][color=Navy]%10000000 [/color][color=Green]'When only the timer is running (normally would have hInt0 & 1 config as well)[/color]
[color=Blue]Symbol tmrIntOn1stTick  [/color][color=DarkCyan]= [/color][color=Navy]65535     [/color][color=Green]'Interrupt to be caused by roll over on first major tick[/color]
[color=Blue]Symbol tmr10mS_16        [/color][color=DarkCyan]= [/color][color=Navy]64911     [/color][color=Green]'= 65536 - (Treq * 1,000,000 / Clk / 256)
'Symbol tmr100mS_8x4     = 62411     '= 65536 - (Treq * 1,000,000 / Clk / 256)
                                    ' Where: Treq = Required Time in microseconds; Clk = 16,000,000.
'[/color]
[color=Black]Init: [/color][color=Blue]let [/color][color=Purple]dirsa[/color][color=DarkCyan]=[/color][color=Navy]%11111111
      [/color][color=Blue]setfreq m16
      'Start the background timer (runs continuously)
      [/color][color=Purple]TOFlag [/color][color=DarkCyan]= [/color][color=Blue]False
      [/color][color=Purple]Timer [/color][color=DarkCyan]= [/color][color=Blue]tmrIntOn1stTick             [/color][color=Green]'
      [/color][color=Blue]SetTimer tmr10mS_16                 [/color][color=Green]'Expires after (every) 100 milliseconds
      [/color][color=Blue]SetIntFlags flgBGTimer[/color][color=Black], [/color][color=Blue]mskBGTimer  [/color][color=Green]'Set timer 0 to interrupt
      ' **** Main Loop ****
      [/color][color=Blue]do
         [/color][color=Green];let direc=1
         ;pause 2000
         ;let direc=0
         ;pause 2000
      [/color][color=Blue]loop
Interrupt:  High oYellowLED
            If [/color][color=Purple]tempmotorspeed [/color][color=DarkCyan]> [/color][color=Navy]0 [/color][color=Blue]then
            [/color][color=Blue]Else
               [/color][color=Blue]if [/color][color=Purple]direc[/color][color=DarkCyan]=[/color][color=Navy]0 [/color][color=Blue]then
            [/color][color=Blue]EndIf[/color]
[color=Black]Int_Enable: [/color][color=Purple]TOFlag [/color][color=DarkCyan]= [/color][color=Blue]False                            [/color][color=Green]'Clear the flag
            [/color][color=Purple]Timer [/color][color=DarkCyan]= [/color][color=Blue]tmrIntOn1stTick                   [/color][color=Green]'Reset the timer
            [/color][color=Blue]Low oYellowLED
            return [/color]
It can easily manage a 10mS timer interrupt. The interrupt routine exits within 3mS, so leaves some time to do other things in the main loop. Not a lot of time, but some :).
stan74
Ok. Nice one Inglwoodpete,your code works much the same as mine when I set timer to 65534 or 5,next tick is overflow,triggers interrupt and resets interrupt,interrupt re-enables itself..correct? or is this where I'm going wrong?
Anyway,please watch the bit pattern leds visibly flashing with your code pasted.If your yellow led was added, it would be flashing.If they flash every 20mS or faster, they would appear fully on so they are not flashing every 10 mS. Please ignore the other youtube carp.
flash
yes, that is where you are going wrong.
You must re-enable the interrupt every time as hippy suggested above (ie another setint before the return). In post 25 you have an extra, unwanted, return before interrupt_Enable:. This prevent the interrupt being re-enabled.
http://www.picaxe.com/BASIC-Commands/Interrupts-and-Multi-Tasking/setint/
2) When the interrupt occurs, the interrupt is then disabled and does not automatically re-enable. Therefore to re-enable the interrupt (if desired) when the interrupt processing is finished another SETINT command must be used within the interrupt sub-procedure itself. This interrupt will not be enabled until the interrupt sub-procedure's 'return' command is executed.
stan74
True Technical, I didn't notice. An hour head scratching and I went code blind. set timer 65535 scopes at 1.8 odd KHz, 20 odd % duty. It's not a myth anymore. On a 16f84 I could get interrupt dual software pwm working and the robot code on the pic. I don't think I'll need it for a stepper driven robot because the core has enough momentum that you don't notice it being off for 20 mS.
Again, thanks all. I'll post a video of the robot in the robot forum when it's finished.How do other people code stepper motor robots? Googleing picaxe interrupt unipolar stepper motor shows little.
stan74
I didn't see the mistake
[color=Blue]Interrupt:
if [/color][color=Purple]tempmotorspeed [/color][color=DarkCyan]> [/color][color=Navy]0 [/color][color=Blue]then
[color=Blue]else
                  let [/color][color=Purple]posrotor[/color][color=DarkCyan]=[/color][color=Navy]7
if posrotor=8 then let posrotor=1. Shows if one cycle is wrong the motor still runs.Making it 7 and you don't see the difference.
set timer 65300 is a tidy value,the motor pins are 37Hz so maybe enough time to do the main program will see.can't be ***** to do more sums.If I was a fisherman I'd have a haddock :)
lbenson
As a resident of Nova Scotia, I've experienced haddock as a nice, white-fleshed fish, the local choice for fish and chips. But I don't understand the perhaps local UK expression, which means ???
flash
The code within my interrupt routine re-enables the interrupt for the next timer expiry. I think yours does too. My code should result in a "solid" yellow LED. It's flashing at 100Hz, so the light will appear steady to us mortals. I can see flashing on the you-tube video but I'm can't tell if this is visible to a person looking at the LEDs or is it a function of the movie camera's shutter synch?
Anyway, is the simulator interrupt still "100 times faster" than my code? It shouldn't be.
stan74
Hi Pete. Haddock-Headache. The leds flash at 38Hz with set timer 65300, slower with your value. The simulator stopped working when simulating the code,displayed unexpected stopped working and pe closed.
Motor stops and doesn't start again if I use pause.
let direc=1 ; motor turns 2/3 revolution clockwise...turns more this direction.
for w6=1 to 1000:next w6 ;takes 4 seconds
let direc=0 ; motor turns 1/3 revolution anticlockwise
Parts of the interrupt run faster..inc dec ??
