I am making a fairly simple system, switch inputs, LED outputs, moderately clever stuff in between, using an 18M2 and Picaxe Editor 6.0.8.11 in Windows 10 on a modestly sufficient Minix box.
Having built and loaded a prototype, I was trying to track down some irrational behaviour but the 'debug' command seemed to lock up the Editor, so I have been using the simulator to explore the code (must learn to set variable values; stepping through is tedious), and noticed something I cannot understand.
I have reduced the code to this for demonstration:
All it does is detect a high input, set an output high after a while, then set the output low when the input goes low; obviously it is inelegant, but shadows the process required in the 'proper' software.
Whilst it works as I would expect when the C.1 input is used, exiting throught to Result:, using the C.0 input locks the simulator up on the 'exit' command on line 13. I cannot understand this.
What is more baffling is that if I comment out the 'do ...loop' lines in the C.1 section, the C.0 sequence then exits properly.
The way out of the freeze seems to be taking the C.4 input high.
Could someone out there comment if this is a problem with the simulator, a stupidity or lack of understanding on my part or my PC running out of puff?
Many thanks.
;init:
#picaxe 18m2
Do
if pinC.0 = 1 then
b0 = b0 + 1
Endif
if b0 > 10 then
high B.1
do while pinC.0 = 1;wait till input low
exit
if pinC.1 = 1 then
b1 = b1 + 1
Endif
if b1 > 10 then
high B.1
do while pinC.1 = 1;wait till input low
exit
result:
low B.1
Many thanks.
