​ ​ ​ ​ Oversized 7 Segment Display - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
Thread: Oversized 7 Segment Display
  1. #21
    Join Date
    Nov 2009
    Location
    UK
    Posts
    1,166
    Default
    Think I have the control Circuit sorted.
    The MSF clock may have to wait, although I am adding the header for it. If I do get to it, or when as I will have some access to it after the new owner takes it I am going to have it check just once a day for the time, in the early hours of the morning. it shouldn't matter if the clock stops for a while to check the time. the rest of the time, time will be kept by a DS3231
    suggestion for changes welcome, going to try and bread board some of it before committing to PCB
    Attached Images Attached Images
    Last edited by westaust55; 18-12-2016 at 06:05. Reason: Corrected clock DS3231 to match diagram
  2. #22
    Join Date
    Feb 2012
    Location
    London
    Posts
    2,869
    Default
    You may need to swap (e.g.) C.6 and C.7. C.6 is an "input only" pin.
  3. #23
    Join Date
    Sep 2011
    Location
    Montpellier (FRANCE)
    Posts
    2,794
    Default
    Quote Originally Posted by oracacle View Post
    the display is multiplexed so switching speed needs to be good...
    ..., going to try and bread board some of it before committing to PCB
    So simple...
    There are 10 types of people in the world: those who understand binary, and those who don't.
  4. #24
    Join Date
    Nov 2009
    Location
    UK
    Posts
    1,166
    Default
    By comparison to learning the correct programming for the LEDs, Surface mounting 200 Plus LEDs masking them out so the pcb can be painted and waiting for them to arrive from where ever they are coming from. That combined with the fact the this has to be some kind of running before Xmas and 6 night shifts to do at the same time, something where half the code already exists is a lot lit simpler.
    Fyi all the bread boarding is done.
    And believe it out boy you most likely don't have all the information about everything
  5. #25
    Join Date
    Feb 2010
    Location
    Don't Mess With My Texas!
    Posts
    2,559
    Blog Entries
    7
    Default
    Sorry for the pun in here, but this application is just 'SCREAMING' for an audio solution. You wouldn't hesitate for an audio solution if the fellow was totally blind.
    - Tex
    These words are my opinion, WYLION. Any resemblance to truth or fiction is accidental at best.
    "Truth lies dormant in our future history." ― Tex Clodhopper LXVI
    "Confidence is ignorance. If you're feeling cocky, it's because there's something you don't know." ― Eoin Colfer, Artemis Fowl
  6. #26
    Join Date
    Nov 2009
    Location
    UK
    Posts
    1,166
    Default
    He's more deaf than blind. You can often hear the TV from the bottom of the drive duty all Windows and doors closed
  7. #27
    Join Date
    Sep 2011
    Location
    Posts
    2,794
    Default
    ??? LED strips are auto adhesive, and you can chose a black strip. No need for pcb, even less for surface mounting.
    But no problem : do it as you want. LED strip was only a suggestion...
    For sure !
    I only know one thing : I don't know anything !
    Merry christmas
  8. #28
    Join Date
    Nov 2009
    Location
    UK
    Posts
    1,166
    Default
    reasonably sure you have missed the point of the original LED density. and for that matter, the density of the 10mm LEDs, the gaps in the strips are not what one would call ideal, its why the LEDs are pushed hard up against one another, its why there would have to go onto a custom board and why there would have to be so many of them - its also the reason why they will cause the same power issues as the original design - something you evidently did not grasp
    I will repeat this, your favourite programmable LEDs are not the answer for things that have more than one LED, its not always the easiest, nor is it always the simplest. For that matter it does into take into account design considerations, deadlines and a whole bunch of other things.
    Edit: Oh dear, the cost would nearly double using APA102 too. cheapest I could find worked out at around £20 per meter for 72 LEDs per meter, 1.12 meters minimum length needed - double that to get rid of the caps in the segments
    120 10mm LEDs, £10, drive components £4 - which gives a better output for the application.
    APA102 doesn't really stack up unless you are doing a lot of colour changing - its probably the only place that they become a more practical way of doing things.
    this display, like the last one only has to display one colour.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
