SETINT on a Picaxe 08M2
FIREMANJIM
The Picaxe Manual #2 is not real clear as to what pins a SETINT can be done on a 08M2 chip.....So I will ask you PROs....What pins on the Picaxe 08M2 chip can I do a SETINT on??? Thanks in advance for all your help....Jim
Interrupts can be used on all pins that can be configured as an input (C.1 to C.4). Refer to "Variables - Special function", page 17 of Manual 2 for input pins.
I have never tried to use an interrupt on the SerIn pin, when configured as a digital input. There may be an expert around who has tested that pin, otherwise, you'll have to test it yourself....
FIREMANJIM
I want to set a Interrupt on C.3 when it goes high. I only want to monitor C.3 so I think the correct binary code would be SETINT %001000, %001000 Is This Correct???
That's correct. The second byte after the SetInt command says "only monitor input 3 (C.3) for interrupts". The first byte indicates that a high condition (1) on pin C.3 will cause the interrupt.
Have you written code for your interrupt routine?
FIREMANJIM
Here is the code Pete:
'Remote Slave Controller
'Picaxe 08m2 chip
Symbol CDSPwr = c.0
Symbol CDSRead = c.1
Symbol SlavePwr = c.2
Symbol PTPwr = c.4
Symbol PTInput = PINC.3
Symbol SerialIn = PINC.5
'set bit variables
Symbol DayStatus = bit0
Symbol SlaveOn = bit1
Symbol PTPwrOn = bit2
'set byte variables
Symbol DayLevel = b2
Symbol DaySetting = b3
Symbol NightSetting = b4
Symbol Counter1 = b5
Symbol Counter2 = b6
'set word variables
Symbol CheckCDSTimer = w3
Symbol CheckCDSTime = w4
Symbol SlaveRefreshTimer = w5
Symbol SlaveRefreshTime = w6
disablebod
Low SlavePwr
Low CDSPwr
Low PTPwr
' set input pins as inputs
Input c.3
Input c.5
' set default variable settings
DayStatus = 1
SlaveOn = 0
PTPwrOn = 0
DaySetting = 128
NightSetting = 117
CheckCDSTime = 6660
SlaveRefreshTime = 6660	'1 second = 111
nap 5
High SlavePwr
SlaveOn = 1
Pause 30000
Low SlavePwr
SlaveOn = 0
Nap 3
High       CDSPwr                    ' apply power to CDS sensor
Nap 5     ' allow power to settle
ReadADC                CDSRead, DayLevel
Low CDSPwr
If DayLevel <= NightSetting Then
     	DayStatus = 0
	High PTPwr
	PTPwrOn = 1
	Pause 500
EndIf
If DayLevel >= DaySetting Then
	DayStatus = 1
	Pause 500
EndIf
Pause 1000
SetFreq m4
SETINT %001000,%001000
MainProgramLoop:
If DayStatus = 1 Then
	Sleep 130
	Low CDSPwr
		DayStatus = 1
	EndIf
     		DayStatus = 0
		If SlaveOn = 0 Then
			High SlavePwr
			SlaveOn = 1
			Pause 25000
			Low SlavePwr
			SlaveOn = 0
			Pause 500
		EndIf
		If PTPwrOn = 0 Then
			High PTPwr
			PTPwrOn = 1
			Pause 500
		EndIf
	EndIf
EndIf
If DayStatus = 0 Then
	SlaveRefreshTimer = SlaveRefreshTimer + 1
	If SlaveRefreshTimer >= SlaveRefreshTime Then
		Counter1 = Counter1 + 1
		SlaveRefreshTimer = 0
	EndIf
	If Counter1 >= 10 Then
		High SlavePwr
		SlaveOn = 1
		Pause 12000
		Low SlavePwr
		SlaveOn = 0
		Counter1 = 0
	EndIf
	CheckCDSTimer = CheckCDSTimer + 1
	If CheckCDSTimer >= CheckCDSTime Then
		Counter2 = Counter2 + 1
		CheckCDSTimer = 0
	EndIF
	If Counter2 >= 10 Then
		Low CDSPwr
     			DayStatus = 0
			Counter2 = 0
		EndIf
			DayStatus = 1
			Counter2 = 0
			If SlaveOn = 1 Then
				Low SlavePwr
				SlaveOn = 0
				Pause 500
			EndIf
			If PTPwrOn = 1 Then
				Low PTPwr
				PTPwrOn = 0
				Pause 500
			EndIf
		EndIf
	EndIf
EndIf
GoTo MainProgramLoop
Interrupt:
High SlavePwr
SlaveOn = 1
Pause 25000
Low SlavePwr
SlaveOn = 0
Counter1 = 0
Beware that word variable w3 occupies the same memory as byte variables b6 and b7.
There is a conflict in your Symbol statements.
