Hi, I am trying to find out the assembly status of the datalogger when purchased. Is self assembly required or it has been preassembled ?
On the AXE110P manual first page, it says that the product is available preassembled. However in section 2 of the same manual, there are instructions for self assembly. Is this because the part numbers for ordering are different ?
Is this a product that can either be connected to the Microbot (since it already has it's own 18X or 18M2 microcontroller) or used independently without the Microbot ?
If it can be connected to the Microbot, where should the connections from the datalogger be made to where (recommended) on the Microbot ?
Once the data is recorded by the datalogger, can the output be parsed on as a txt file ?
