These look as if they may well be a really nice solution to an always challenging problem - thanks for posting and highlighting them, I may well not have spotted them in the Picaxe store.
I have a small milling machine and must have milled out a dozen display apertures, but even with this machine it's time consuming setting the box/panel up in the machine, milling out the hole and then cleaning it up and de-burring the edges, especially in some plastic boxes, that almost always leave a "fuzz" on one side of the cut. Being able to just cut a larger hole and then fit one of these seems to be just the job.
One thing I'd like to try is using one of these with the display fitted inside a clear polycarbonate box. In the past, I've masked off a window very carefully, then spray painted the clear box. When the paint has dried the masking tape can be removed, leaving a clear window for the display. This technique works well, but it's very difficult to get a nice, clean, edge between the paint and the clear window. With one of these bezels the masked area could be larger, so the edge is hidden under the bezel. A smear of clear silicone sealer around the screws would maintain a rain-proof front. The unit in question is my electric bike "fuel gauge" and power switch, which is fitted to the handlebars of my home made electric bike:
I can see an order for a few of these on the horizon......................
