I have tried this on the tutorial:
4. Connect an LED and 330 ohm resistor to the output pin 4 of the PICAXE chip.
high B.4
low B.4
And it worked!
I changed to B.4 again and put the wire in B.4
The ground in 0V
The resistor between the B.4 and the anode, with the program in between(if you know what I mean).
Now it works. Great.
high B.4
low B.4
And it worked!
The ground in 0V
