​ ​ ​ ​ PicAxe peak-detecting NiMh battery charger
Results 1 to 5 of 5
Thread: PicAxe peak-detecting NiMh battery charger
  1. #1
    Default PicAxe peak-detecting NiMh battery charger
    After having trouble making switchmode battery chargers, I decided to build one using an LM317 adjustable regulator and series resistor as a constant current source. Gets hot but works well. Schematic designed on Eagle. PCB produced with Oshpark.
    #terminal 4800
    init:
    ;set up inputs and outputs
    symbol battery = c.4
    symbol chargeoutput = c.2
    symbol led = c.1
    ;set up variables
    symbol current = w0
    symbol flashcount = w1
    symbol currentsum = w2
    symbol dutycyc = w3
    symbol voltcount = w4
    symbol volts = w5
    symbol voltavg1 = w6
    symbol voltsum = w7
    symbol peakvolt = w8
    symbol deltapeak = w9
    symbol modulus = w10
    symbol highvolt = w11
    symbol endcount = w12
    ;set everything to zero
    dutycyc = 0
    current = 0
    currentsum = 0
    voltcount = 0
    volts = 0
    voltavg1 = 0
    voltsum = 0
    peakvolt = 0
    deltapeak = 0
    ;flash led to signify startup
    low led
    for flashcount = 1 to 20
    	toggle led
    	pause 100
    next flashcount
    start:
    ;detect battery inserted
    gosub battdetect
    ;main charge loop
    high chargeoutput
    ;for next loop to run for about 30 seconds between checking battery voltage
    for voltcount = 0 to 2399
    pause 10
    ;blink led to signify charging
    modulus = voltcount // 20
    if modulus = 0 then
    	toggle led
    next voltcount
    ;measure voltage of battery
    gosub verifyvolts
    ;check voltage, and go to beginning if battery is removed
    if volts < 400 then init
    ;update peakvolt variable if voltage reading is higher than the last reading
    if volts > peakvolt then
    	peakvolt = volts
    	deltapeak = 0
    ;check if voltage dropped below peak, then increment a counter
    if volts < peakvolt  then
    	inc deltapeak
    ;check counter value to end charge after battery voltage drops below peak for two cycles
    if deltapeak > 1 then endchg
    ;send voltage adc value to terminal
    sertxd (#volts, cr)
    battdetect:
    ;check voltage to detect inserted battery
    gosub verifyvolts
    if volts <400 then start
    low chargeoutput
    endchg:
    ;turn off charging current when charging complete
    low chargeoutput
    endchg1:
    ;loop to detect removal of charged battery and go to start if battery is removed. LED lit solid to signify charging complete.
    high led
    gosub verifyvolts
    sertxd (#volts, cr)
    goto endchg1
    verifyvolts:
    ;measure battery voltage
    ;shut off charging current to get accurate battery voltage
    low chargeoutput
    ;use internal voltage reference
    fvrsetup FVR2048 ; set to 2.048V
    adcconfig %011
    volts = 0
    voltsum = 0
    voltavg1 = 0
    ;take several readings and average
    for voltavg1 = 0 to 19
    readadc10 battery, volts
    voltsum = volts + voltsum
    next voltavg1
    volts = voltsum / 20
    ;measurement done, turn on charging current
    high chargeoutput
  2. #2
    Join Date
    Jul 2008
    Location
    Potton, Bedfordshire, UK
    Posts
    6
    Default Peak detecting NiMh charger
    Hi sniper887,
    I have looked with interest at your peak detecting charger project here and want to build one but you don't mention what the voltage is of the battery being charged.
    Maybe it doesn't matter as the software takes care of it - you are only interested in the downward change of battery volts to terminate the charging process.
    Also I was wondering whether a resistor is missing on your schematic from PIC pin 3 to Gnd., to scale down the battery volts to with the range of the A/D and not exceed 5 volts.
    Regards,
    SignalX
  3. #3
    Default
    Quote Originally Posted by SignalX View Post
    Hi sniper887,
    Regards,
    SignalX
    I did intend to have the full-scale battery voltage get measured at the ADC pin. The resistor and capacitor are for just filtering. They might not be needed since the current source is just a linear regulator. If i was charging more than one or two cells I'd probably need a voltage divider.
  4. #4
    Join Date
    Jan 1970
    Location
    Perth, Western Australia
    Posts
    4,304
    Default
    Hi sniper887,
    Actually, it's not the software that determines the range of battery voltages that can be charged - it's the hardware. That 1.5ohm resistor fools the regulator into supplying a constant current regardless of the voltages involved. The supply voltage is the limitation of the circuit and that is only limited by the capabilities of the various components.
    The software monitors the battery voltage for a drop to determine when the battery/cells have reach full charge. When charging only one cell (1.4v fully charged), the PICAXE's ADC struggles to reliably detect the voltage drop off due to it being only a few millivolts. This sort of circuit works best with two or more cells.
  5. #5
    Join Date
    Feb 2010
    Location
    Don't Mess With My Texas!
    Posts
    2,133
    Default
    Quote Originally Posted by sniper887 View Post
    ... Gets hot but works well....
    Missed this the first time around, but the heating power developed can be reduced by bringing the input voltage down to some voltage closer to the output voltage.
    In other words, the power produced can be reduced by reducing the voltage across the regulator circuit.
    You start with 12VDC and charge "one or two cells". That's a significant difference in voltage dissipating heat in the regulator.
    - Tex
    "Truth lies dormant in our future history." ― Tex Clodhopper LXV
    Confidence is ignorance. If you're feeling cocky, it's because there's something you don't know. ― Eoin Colfer, Artemis Fowl
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
