Haviing trouble simulating the srlatch
Buzby
I'm trying to simulate the srlatch being set when c.1 ( the SRI pin ) goes high.
What am I doing wrong ?
Cheers,
Buzby
[color=Navy]#picaxe [/color][color=Black]08M2[/color]
[color=Navy]#no_data[/color]
[color=Green]' PE 6.0.8.9[/color]
[color=Blue]high c.2 [/color][color=Green]' Make SRQ an output[/color]
[color=Blue]pause [/color][color=Navy]1000[/color]
[color=Green]' Set latch when SRI is 1
 [/color][color=Blue]srlatch [/color][color=Navy]%10001000[/color][color=Black], [/color][color=Navy]%10000000 [/color]
[color=Blue]do
pause [/color][color=Navy]100 [/color][color=Green]' Put 'test for latch set' here [/color]
[color=Blue]loop [/color]
AllyCat
Looks like a bug/oversight in PE6 (I've just tried 6.0.8.4) .
The code seems to simulate correctly in PE5.
Buzby
I've got a new laptop, so I installed PE6 as my only PE.
Should have stuck with PE5 !.
Buzby
Now I've just discovered that the srlatch clocked set/reset is not supported in PE5 or PE6 !.
I'll just have to build the hardware before I write the software.
AllyCat
I'm not sure how "useful" is the clocked part of the SR-Latch, when using a PICaxe, because even its longest prescaler delay executes faster than a single PICaxe instruction.
How are you planning to use the SR-Latch? I have found the Latch(es) within the "Timer 1 Gate" hardware (which can be used totally independently of Timer 1) to have some useful features.
Buzby
Hi Alan,
I must admit I wasn't planning on using the clocked set/reset, but it would be nice if it could be simulated.
I've not investigated the timer 1 gating, have you got any examples, or a link to the datasheet ?.
I'm trying to emulate something like the 'wake on interrupt' ( sleep 0 ) that the X2's can do, but on an 08M2, and active on both rising and falling edges.
Cheers,
Buzby
AllyCat
Hi Buzby,
I had been planning to post a Code Sniippett on the Timer1 Gate, but some time ago replied to another topic.
Maybe I will submit a detailed Code Snippett soon (to use either with or without Timer 1) , but for now the key diagrams (from the relevant base PIC data sheet) are in post #10 of the link above. Its particular strength is that the PICaxe Code can read the Latch status, but I'm not sure it would help your particular application.
Hemi345
Yeah, looks like a bug with the 08M2. The simulating almost the same code with the 20M2 works as expected:
#picaxe 20M2
#no_data
' PE 6.0.8.9
high b.1 ' Make SRQ an output
 srlatch %10001000, %10000000
	pause 1000 ' Put 'test for latch set' here
Buzby
Hi Alan,
That's clever use of the T1GCON register, but I don't think it will help me unless the gate is active during sleep, which I don't think it is.
Also, I maybe able to accommodate the fact that the srlatch is level triggered, not edge triggered, by judicious placement of the vibration switch I'm using to wake up.
Cheers,
Buzby
