Jeremy Harris
At the moment, the HC-12 tool doesn't return any indication that the programming has completed, other than the button returning from greyed out to normal. The check configuration button will show the actual settings, reading them from the module.
The error messages are internal glitches in the tool, that stop it sending the next command in sequence, unless the error is cleared by clicking "OK". I don't know for sure, but I'm guessing that the tool is parsing the expected return string, say "OK+B1200" as the response from an HC-12 to the command "AT+B1200". If it gets that string, it then sends the next command in the sequence, if it doesn't get that string it halts and flags an error, only continuing when the error is cleared manually.
It's probably fairly straightforward to change the expected strings for the HC-11 to be "OK-", rather than "OK+", I suspect.
