binary1248
I am using an 08M2 to delay fan shutdown on a motorcycle (and two channels of thermistor data logging) and after a delay of when the ignition turns off I will shut the fans off. After the fans shut off I will use "sleep" to reduce the power drain.
My question is, what is the power drain of an 08M2 in none sleep and sleep mode (disregarding any external output loads during non sleep modes.). I have searched the forums but didn't find the info.
The code is written and I guess I can set up the bread board and measure, but maybe some one already knows the answer.
After I get the sleep mode working may also use "disablebod" to further reduce power, but that's for a later code test...
The fans will be controlled by a power FET.
Paul
Paul
