magnetometer with 28x2
'''    mag_quad_1_28x2_2.bas
''''   prgm simulates printing out
''''    sample readings from  compass
''''  chip HMC5883L
''''    convert 2s complement display
#picaxe  28x2
#com /dev/tty.usbserial-00001004
#terminal 9600
symbol x_lin =w0
symbol x_lin_lsb = b0
symbol x_lin_msb = b1
symbol y_lin =w1
symbol y_lin_lsb = b2
symbol y_lin_msb = b3
symbol z_lin =w2
symbol z_lin_lsb = b4
symbol z_lin_msb = b5
symbol  loop_m = b23
symbol loc_pp = b24
symbol pass_x = b17
symbol angl_1  = w3
symbol end_angl = w4
symbol quot_x = w5
symbol m = b18
symbol p = b19
symbol  x_sign  = b20
symbol  y_sign = b21
symbol quad_val = b22
symbol x_tmp = w6
symbol y_tmp = w7
'''loc_pp = 100     '''''   INIT  POKE  LOC
pass_x = 1
m = 0
p = 1
serout c.0 ,n2400,(254,1)
pause 500
serout c.0, n2400, ( " HELLO   WORLD" )
    wait 3
'''''do
'''''loop
hi2csetup i2cmaster ,$3c, i2cslow, i2cbyte   '''' INIT  I2C
pause 500
hi2cout $00,($18)
pause 500
hi2cout $01, ($00)
pause 500
 for loop_m = 1 to 4
serout c.0, n2400, (254,1)
pause 500
serout c.0,n2400,("loop = ",#loop_m)
wait 2
hi2cout $02,($01)    ''''  request single measurement
pause 500
hi2cin $03,(x_lin_msb,x_lin_lsb,z_lin_msb,z_lin_lsb,y_lin_msb,y_lin_lsb)
pause 500
          if x_lin_msb > 127 then
    '''  number is negative
    x_sign = m
    x_lin = x_lin xor 0xffff
    inc x_lin
pause 500
serout c.0, n2400, ( " x  =  -",#x_lin)
    pause 500
    x_sign = p
    pause 500
    serout c.0, n2400, ( " x  = +",#x_lin)
    pause 500
wait 1
if y_lin_msb > 127 then
    y_sign = m
    y_lin = y_lin xor 0xffff
    inc y_lin
    serout c.0 ,n2400,(254,192)
pause 500
serout c.0, n2400, ( " y  =  -",#y_lin)
    pause 500
    y_sign = p
    pause 500
    serout c.0, n2400, ( "  y  = +",#y_lin)
    pause 500
wait 1
inc pass_x
    pause 500
    serout c.0, n2400, ( " end_pass ",#pass_x)
    pause 500
    wait 2
serout c.0,n2400,(254,192)
pause 500
serout c.0,n2400,("quad = ",#x_sign,#y_sign)
wait 2
next
'''  pass_x = 4
'''   x and y positive
'''  I can use WORDS x_lin and y_lin
'''   for computations
pause 500
''' start processing x_lin and y_lin
wait  1
''''   CALCULATE   QUAD_VAL
if x_sign = p then
    if y_sign = p then
        quad_val = 1
        quad_val = 4
if x_sign = m then
    if y_sign = m then
        quad_val = 3
        quad_val = 2
if x_lin > y_lin then
    y_tmp =y_lin
    y_tmp = y_tmp * 100
    quot_x = y_tmp/ x_lin
angl_1 = atan quot_x
pause 500
    x_tmp = x_lin
    x_tmp = x_tmp  * 100
    quot_x  = x_tmp / y_lin
    pause 500
    ''serout c.0,n2400,(254,1)
    ''pause 500
    '''serout c.0,n2400,("angle is ",#angl_1)
    ''''pause 500
    ''''  DISPLAY FULL  ANGLE
      select case quad_val
      case   1
          if y_lin > x_lin  then
              angl_1 = 90 - angl_1
      case  2
          angl_1  = angl_1  + 90
      case  3
          angl_1 = angl_1 + 180
      case 4
          angl_1 = angl_1 +270
      end select
      wait  3
    pause 500
    serout c.0, n2400, ( " angle is  ", #angl_1)
    pause 500
stop
beep_2:
high c.1
pause 500
low c.1
pause 500
high c.1
pause 500
low c.1
pause 500
beep_1:
high c.1
pause 500
low c.1
pause 500
HMC5883L 3-axis compass
For those not familiar with the HMC5883L, it is a 3-axis compass module.
@larryatheist,
Well done and thanks for posting - for furture reference by all.
For your future reference, the 2-compliment calculation (albeit the same as what I was using many years earlier),
can be reduced from:
    inc x_lin_adj
to:
    x_lin = -x_lin
which also happens to save ~4 bytes at each instance
