larryatheist
''' mag_quad_1_28x2_2.bas
'''' prgm simulates printing out
'''' sample readings from compass
'''' chip HMC5883L
'''' convert 2s complement display
#picaxe 28x2
#com /dev/tty.usbserial-00001004
#terminal 9600
symbol x_lin =w0
symbol x_lin_lsb = b0
symbol x_lin_msb = b1
symbol y_lin =w1
symbol y_lin_lsb = b2
symbol y_lin_msb = b3
symbol z_lin =w2
symbol z_lin_lsb = b4
symbol z_lin_msb = b5
symbol loop_m = b23
symbol loc_pp = b24
symbol pass_x = b17
symbol angl_1 = w3
symbol end_angl = w4
symbol quot_x = w5
symbol m = b18
symbol p = b19
symbol x_sign = b20
symbol y_sign = b21
symbol quad_val = b22
symbol x_tmp = w6
symbol y_tmp = w7
'''loc_pp = 100 ''''' INIT POKE LOC
pass_x = 1
m = 0
p = 1
serout c.0 ,n2400,(254,1)
pause 500
serout c.0, n2400, ( " HELLO WORLD" )
wait 3
'''''do
'''''loop
hi2csetup i2cmaster ,$3c, i2cslow, i2cbyte '''' INIT I2C
pause 500
hi2cout $00,($18)
pause 500
hi2cout $01, ($00)
pause 500
for loop_m = 1 to 4
serout c.0, n2400, (254,1)
pause 500
serout c.0,n2400,("loop = ",#loop_m)
wait 2
hi2cout $02,($01) '''' request single measurement
pause 500
hi2cin $03,(x_lin_msb,x_lin_lsb,z_lin_msb,z_lin_lsb,y_lin_msb,y_lin_lsb)
pause 500
if x_lin_msb > 127 then
''' number is negative
x_sign = m
x_lin = x_lin xor 0xffff
inc x_lin
pause 500
serout c.0, n2400, ( " x = -",#x_lin)
pause 500
x_sign = p
pause 500
serout c.0, n2400, ( " x = +",#x_lin)
pause 500
wait 1
if y_lin_msb > 127 then
y_sign = m
y_lin = y_lin xor 0xffff
inc y_lin
serout c.0 ,n2400,(254,192)
pause 500
serout c.0, n2400, ( " y = -",#y_lin)
pause 500
y_sign = p
pause 500
serout c.0, n2400, ( " y = +",#y_lin)
pause 500
wait 1
inc pass_x
pause 500
serout c.0, n2400, ( " end_pass ",#pass_x)
pause 500
wait 2
serout c.0,n2400,(254,192)
pause 500
serout c.0,n2400,("quad = ",#x_sign,#y_sign)
wait 2
next
''' pass_x = 4
''' x and y positive
''' I can use WORDS x_lin and y_lin
''' for computations
pause 500
''' start processing x_lin and y_lin
wait 1
'''' CALCULATE QUAD_VAL
if x_sign = p then
if y_sign = p then
quad_val = 1
quad_val = 4
if x_sign = m then
if y_sign = m then
quad_val = 3
quad_val = 2
if x_lin > y_lin then
y_tmp =y_lin
y_tmp = y_tmp * 100
quot_x = y_tmp/ x_lin
angl_1 = atan quot_x
pause 500
x_tmp = x_lin
x_tmp = x_tmp * 100
quot_x = x_tmp / y_lin
pause 500
''serout c.0,n2400,(254,1)
''pause 500
'''serout c.0,n2400,("angle is ",#angl_1)
''''pause 500
'''' DISPLAY FULL ANGLE
select case quad_val
case 1
if y_lin > x_lin then
angl_1 = 90 - angl_1
case 2
angl_1 = angl_1 + 90
case 3
angl_1 = angl_1 + 180
case 4
angl_1 = angl_1 +270
end select
wait 3
pause 500
serout c.0, n2400, ( " angle is ", #angl_1)
pause 500
stop
beep_2:
high c.1
pause 500
low c.1
pause 500
high c.1
pause 500
low c.1
pause 500
beep_1:
high c.1
pause 500
low c.1
pause 500
