Storing words in bptr
oracacle
I am re-writing the code for the macro rail due to changes in the equations that are used.
I am currently facing a slight shortage of variables. some of the data that I am using isn't used that often, primarily for storing previous data. a fair amount of this info is stored as words as it can exceed 255. will I need to store the info in a high and low byte fashion?
I presume its ok to assign variable to the point ie
symbol store = 56
symbol stuff = b0
bptr store
@bptr = stuff
is it also possible to use @bptrinc to write the data, and for that matter read the data directly back from external eeprom
if this is all true I presume its also safe to use @bptr directly in if statements, would that be a correct assumption?
oracacle
thanks westaust
would I be correct in saying that this code will store w0 (stuff = 2016) into the bptr addresses of 56 and 57
[color=Blue]symbol store      [/color][color=DarkCyan]= [/color][color=Navy]56[/color]
[color=Blue]symbol [/color][color=Purple]stuff      [/color][color=DarkCyan]= [/color][color=Purple]w0
      [/color][color=Blue]symbol [/color][color=Purple]stuff_low  [/color][color=DarkCyan]= [/color][color=Purple]b0
      [/color][color=Blue]symbol [/color][color=Purple]stuff_high [/color][color=DarkCyan]= [/color][color=Purple]b1
      [/color]
[color=Black]main:
      [/color][color=Purple]stuff [/color][color=DarkCyan]= [/color][color=Navy]2016
      [/color][color=Purple]bptr [/color][color=DarkCyan]= [/color][color=Blue]store
      [/color][color=Purple]@bptr [/color][color=DarkCyan]= [/color][color=Purple]stuff_low
      @bptrinc [/color][color=DarkCyan]= [/color][color=Purple]stuff_high
      [/color][color=Blue]end[/color]
You can use bptr, @bptr, @bptrinc and @bptrdec as you suggest; you can basically use those anywhere you could use any variable with just a few exceptions.
When reading or writing a word the inc ( or dec ) would be after the first byte read or written ...
bptr = store
@bptrinc = stuff_low
@bptr = stuff_high
oracacle
thanks hippy, I was just about to post the test code I quickly tried and found that just now.
I did use bptr and its variants for reading data onto a display for the timer project, but I was not using word variable than.
thanks all
lbenson
You can also use peek/poke with bptr to store/retrieve as many sequential bytes as you want:
symbol store      = 56
symbol stuff      = w0
symbol storeFrom  = 0  ' in bptr, equivalent to address of b0
      stuff = 2016
      bptr = storeFrom
      poke store,@bptrinc,@bptr
      end
