Hi All,
I've been working on a project that records data to openlog. Communication with OL work great, except for one thing... the control characters (ctrl Z) keep showing up when I go to command mode. I've tried all kinds of config.txt combinations for the OpenLog, but to no avail. Perhaps someone has solved this problem? Or perhaps I'm not implementing code correctly. At any rate, I'd appreciate some feedback.
In the attached code snippet you can see how I handle the command mode. And the attached a sample data file to show the results. Notice the three ctrl Z characters showing up as arrows.
Just to give you a quick overview, I maintain several different data files, each of which gets periodic additions as the program runs.
Any suggestions will be appreciated as the characters showing up are not a project killer, but mighty irritating.
John
John
