model parking garage help
i am halfway through making a model parking garage for a school. here is a basic diagram of what it does
after completing the individual subsystems i have run intp some trouble with adding the fist barrier arm subsystem to the main code. ( when added,the servo arm moves more tan it did on its own)
is
#Terminal 4800
Symbol spacesLeft  = b0
Symbol spacesShown = b1
Symbol entryBeam   = b2
Symbol exitBeam    = b3
Symbol ENTRY_ADC   = B.4
Symbol EXIT_ADC    = C.4
Symbol BROKEN      = 10
; Display routine
Start0:
  serout B.1,N2400,(254,1)
    pause 30
  spacesLeft = 4
  Pause 500
  SerTxd( CR, LF )
  SerTxd( "Starting...", CR, LF )
    spacesShown = spacesLeft
    If spacesShown = 0 Then
      SerTxd( "Full - No spaces left", CR, LF )
    Else
      SerTxd( "Spaces Left = ", #spacesShown, CR, LF )
      serout B.1,N2400,(254,128)   ; move to start of first line
   serout B.1,N2400,("places availible")  ; output text
   serout b.1, n2400, ( 254, 192 ) 'second line
  serout b.1, N2400, (#spacesshown)
    Do : Loop Until spacesShown <> spacesLeft
; Handle the entry beam
Start1:
    Do : ReadAdc ENTRY_ADC, entryBeam : Loop Until entryBeam <= BROKEN
    Do : ReadAdc ENTRY_ADC, entryBeam : Loop While entryBeam <= BROKEN
    spacesLeft = spacesLeft - 1
  if spacesleft = 0 then
  serout b.1, n2400, ( 254, 128 ) 'second line
  serout b.1, n2400, ( "park is full " )
  elseif spacesleft > 0 then goto Start1
    'Do : Loop Until spacesShown <> spacesLeft
; Handle the exit beam
Start2:
    Do : ReadAdc EXIT_ADC, exitBeam : Loop Until exitBeam <= BROKEN
    Do : ReadAdc EXIT_ADC, exitBeam : Loop While exitBeam <= BROKEN
    spacesLeft = spacesLeft + 1 Max 4
start3:
servo b.3, 80 ;set the initial servo position @  position 137
arm1:
irin b.2,b0
debug
if b0>=20 then up
if b0<20 then down
goto arm1
up:
servopos b.3, 180 ;change the servos position without reseting the timer
pause 500
goto arm1
down:
servopos b.3,80
pause 500
goto arm1
rossko57
start3:
irin b.2,b0
If you allocate a variable for one purpose (counting spaces) it is really unwise to allow some other routine to alter it for a completely different purpose (reading beams)
As variable b0 is generally useful for all sorts of odd jobs, it is probably a good idea to leave that as an unallocated working space (for things like reading beams) and to redesignate your spaces counter to some other variable.
By "moves more" do you mean moves more frequently or moves a greater distance when opened / closed ?
#Terminal 4800
Symbol BROKEN      = 10
; Display routine
Start0:
    pause 30
  spacesLeft = 4
  Pause 500
  SerTxd( CR, LF )
    Else
Start1:
Start2:
start3:
arm1:
irin b.2,b4
debug
if b4>=20 then up
if b4<20 then down
goto arm1
up:
pause 500
goto arm1
down:
servopos b.3,80
pause 500
goto arm1
