I think that zigBee can do the job.What is the best way to do that? It must be encrypted.
Encrypted to what standard is the very obvious question ?I have a project with 1 master and 5 slave units. All are connected with cable at the moment. I can't have cable connections longer and need to have a wireless connection between the units. What is the best way to do that? It must be encrypted.
That is because there can be a second set of master and slave's in the active operating area and see each other.Encrypted to what standard is the very obvious question ?
You might want to help everyone by explaining the application and exactly why the comms needs to be 'encrypted'.
If so, no need for encryption ; simply use differents channels (there are 15 on Xbee...)That is because there can be a second set of master and slave's in the active operating area and see each other.
They may only see there own set.
It sounds like you are currently using I2C, but need longer distances than the buss can cope with..... I have a project with 1 master and 5 slave units. All are connected with cable at the moment....
