Hi All, I use Picaxe with my Meccano hobby.
My question. Can I use an infrared receiver with Picaxe Project Board CH1035A? I can't see any reference to infrared commands on 18m2 data sheet.thanks all.Ernest
The Axe040 data sheet (IR tx & rx kit) says you can use input 0 (pin C.0?) on the CHI030/035.
I think you can also use other inputs but you would need to remove the 10K pull down resistor?
I am certain the command is available on an 18M2 (in fact all M2's?).
