Hello All
I was given a 5 pin HY-SRF05 Ultrasonic Distance Sensor Module for Arduino. I am trying to use it with a 14M2 chip. I have looked through the threads in the forum and also at lets make robots with no luck at this point. The pins are in this order VCC, TRIG, ECHO, OUT, GND. I have also looked at the information presented on
http://www.robot-electronics.co.uk/htm/srf05tech.htm that talks about the upgrade from the SRF04 to SRF05, still nothing. Has anyone used these successfully with a picaxe? i would be grateful for any advice as to get working.
Thank you
Gaetano
Thank you
Gaetano
