Hi.
We've downloaded the executable to install the driver for the USB cable, but I think that this method of install is at best inconvenient for a large school from what I can see, as you still need to approve the install of the driver as an administrator? We block student accounts from accessing device manager, so I believe that the process is a manual installation on each computer as the local administrator. When you're rolling this driver out to 100 desktops in a school, it's frustrating. Assuming I've got the method of install correct, is there any plan to create a driver installation that once installed will plug-and-play the cable without requiring this manual process?
We are currently building material for a project based on this cable, but we have only one cable as it stands at the moment, as we're just testing. We intend to purchase many more. Are all of the cables identical when plugged in via USB so one AXE027 cable is seen to a computer as identical to another, or when a different AXE027 is plugged in, will it go through the process of plug-and-play again followed by a manual driver install, assuming an earlier install of the driver with a different cable has succeeded?
The cable has a 3.5mm jack plug.
Can I please ask - if this gets plugged into an audio port on the computer, or on another computer, or a phone/MP3 player, could something get damaged? In a secondary school it's bound to happen, and I'd prefer not to test it myself!
Thanks ever so much.
