Time and Time again
ZOR
Can you have more than 1 instance of TIME working at the same time?
ie TIME1, TIME2. So I can have TIME1 running and while running reset TIME2 to zero, TIME2 being used to time another procedure.
Hope this is understood. Thanks
There is only one 'time' variable.
There is no way I can see to have 'time1' and 'time2' variables separately and automatically keeping track of their own elapsed time but it can perhaps be done programmatically.
This code will toggle B.1 every second, toggle B.2 every two seconds -
#Picaxe 20M2
Symbol lastTime = w0
Symbol time1    = w1
Symbol time2    = w2
MainLoop:
  Do
    Gosub UpdateTimers
    If time1 >= 1 Then
      time1 = 0
      Toggle B.1
    End If
    If time2 >= 2 Then
      time2 = 0
      Toggle B.2
    End If
  Loop
UpdateTimers:
    Do While time <> lastTime
      inc lastTime
      inc time1
      inc time2
    Loop
    Return
You could split that out for a multi-tasking program if you desired that format -
#Picaxe 20M2
Symbol lastTime = w10
Symbol time1    = w11
Symbol time2    = w12
Start0:
  Do
    Gosub UpdateTimers
  Loop
Start1:
  Do
    If time1 >= 1 Then
      time1 = 0
      Toggle B.1
    End If
  Loop
Start2:
  Do
    If time2 >= 2 Then
      time2 = 0
      Toggle B.2
    End If
  Loop
UpdateTimers:
    Do while time <> lastTime
      inc lastTime
      inc time1
      inc time2
    Loop
    Return
lbenson
You can look at it the other way around if you're counting seconds.
Time1Event = 10
Time2Event = 15
Time = 0
  if time >= Time1Event then
    do something
    Time1Event = time + 10 ; or $FFFF to turn off
  if time >= Time2Event then ; do something else
  if time >= 43200 then  ' half a day, 12 hours, 60*60*12
    if time1Event <> $ffff then
      time1Event = time1Event - time ' remaining time to event--may wish to confirm that time1Event not < time
    if time2Event <> $ffff then
      time2Event = time2Event - time ' remaining time to event2
    time = 0 ' reset for another 12 hours
And so on for as many events as you would want.
ZOR
Many thanks everyone, that answers the problem properly with useable code. Thanks again for the work put in.
Jeremy Harris
Bear in mind that the internal time variable stops whenever there is a blocking instruction. This caught me out recently, when I was using a serin instruction and discovered that time just stops incrementing whilst serial data is being received. I believe that any blocking instruction has the same effect.
ZOR
Thanks Jeremy, I did not know that. Fortunately I have moved this part of the code to the serout side prior to sending serial data. I will remember that in future, thanks again
