I've been looking at various archived posts on measuring salinity. I haven't found much. And what I've found doesn't quite do it for my project. I'm trying to design a sea water salinity probe. Here are the characteristics I'm looking for:
Must be reasonably accurate (not looking for the n'th decimal place!)
Must be low cost; low component count; low power consumption (especially)
Probe portion needs to last only 6mo or so submerged (I know conductivity is hard on probes)
Data will be logged, analyzed after the fact
So my idea is to use the PicAxe to generate an alternating signal (as per previous posts) and using a simple gold plated 0.1 inch spacing straight header as the probe. Depending on the total surface area needed to get a good reading, I could use multiple alternating contacts (say 1,3,5,7 and 2,4,6,8 on an 8 pin header) and either the short or the long side of the header. The other side of the header would be encased in epoxy and wired to the PicAxe. If such a probe can work, it would certainly be a cheap "throw-away" that could be replaced anytime the sensor package is newly deployed. But I'm wondering if the gold plating won't stand up to the abuse quite well. We'll find out!
I've read hints at using electromagnetic techniques and wonder if they might work instead of sticking metal into sea water? If cost and power consumption can be controlled, it would be ideal. I'm not holding out much hope for that, however.
A lot of you "Axers" out there are much more astute than me when it comes to making the electronics work. I'd appreciate your thoughts and suggestions before I dive in, especially if you've played with salinity measurement. The overall project I'm working on is a low cost, multi-sensor marine module meant to be deployed for months at a time to log environmental changes. When completed, the module will be used for long term environmental studies. It will also have application in water quality measurement (and control) for recirculating aquaculture and photobioreactors (all of which I'm involved with).
Thanks in advance.
Thanks in advance.
