fernando_g
The snippet below actually consists of two routines. Each one with (slight) advantages or disadvantages to the other.
Use only one.
Use only one.
testing of two routines which provide hysteresis to a compared value.
'In this example, I'm adding +/- 11 counts to a setpoint value of 128
'Using 08M2 port C.1 as analog input, port C.0 as output
'first routine, more lines, less compiled bytes (24)
schmitt_trig1:
readadc C.1, b0
if pinC.0 = 1 then
goto lohyst
hihyst: 'C.0 =0
if b0 >139 then
high C.0
lohyst: 'C.1 =1
if b0 <117 then
low C.0
'second routine, more compact, more compiled bytes (26)
schmitt_trig2:
readadc C.1, b0
if b0 >139 and pinC.0 =0 then
high C.0
elseif b0 <117 and pinC.0 =1 then
low C.0
