Hi guys, at the minute i have two 08M2's communicating with each other through IR and I wish to use the debug command to check what commands are being sent to the IR Rx. I also just want to try the debugging feature out purely because it seems very useful. Basically I've been searching for a way to connect a picaxe to the COM port from a breadboard so that the serial commands can be sent from the picaxe to the PC. So far i have stumbled upon an image online that shows the difference between the connections for serial uploading and downloading, is this image correct?
