professor_jonny
So I have come across another bug.
program attached
In the attached program if I enable toggle mode it runs two cascading sub routines "button check" and "beep select" between output blocks .
In one of the sub routines it runs:
But the output pins fail to switch to inputs and enable high z between rolling to the next output so the outputs that are not forced high or low in the block should be set to high z but they say set as per the previous output block.
basically the the above code is ignored in the sub routine.
program attached
input B.3, B.4, B.5
