DIG command causes a syntax error
mikepanchaud
The code below runs OK when the Picaxe type in the emulator is set to 20X2 or higher
BUT, returns a syntax error if the Picaxe type is set to 08M2 !?
I'm running the latest emulator version 6.0.8.0.
What am I doing wrong?
Thanks in advance.
Mike.
LET b0=247
LET b1 = b0 DIG 0		' returns units digit
LET b2 = b0 DIG 1		' returns tens digit
LET b3 = b0 DIG 2		' returns hundreds digit
' DIG returns a BCD digit
' b1 = 7
' b2 = 4
' b3 = 2
' This code runs OK when the picaxe type in the emulator is set to 20X2
'BUT
' returns a syntax error if the Picaxe type is set to 08M2  !?
srnet
Thanks in advance.
Mike.
LET b0=247
' b1 = 7
' b2 = 4
' b3 = 2
'BUT
The manual says on page 22;
The X1 and X2 parts also support
<< ; shift left
>> ; shift right
*/ ; multiply (returns middle word of result)
DIG ; return the digit value
REV ; reverse a number of bits
mikepanchaud
Thanks for that info.
Here's my solution for the 08M2
LET b0=247
LET b1 = b0//10		'b1= units
LEt b2 = b0/10
LET b2 = B2//10 		'b2 = tens
LET b3 = b0/100		'b3 = hudreds
LET b3 = b3//10
'  // = modulus divide
