WTV020-SD-20SS
A few days ago I bought one of these cheap modules on ebay with the ambition of adding voices to a project, taking advice from this forum I managed to buy an SD card that was compatible and soon got it working in "Key Mode" but of course I wanted a picaxe to control it and that was when I ran into difficulties.
I am sure the code is right and have checked the output on my scope (see photo) but after several days I've had no joy. Looking round on internet I found some suppliers say that it must be programmed into serial mode at manufacture, does anyone know if this is correct as the add did not suggest this.
I have also included my latest code if anyone can see anything wrong there I would be very grateful for any help or suggestions as I have spent many many hours trying to solve the problem and got nowhere. (Hope I've done the attachment and code right )
#picaxe 18m2
Symbol mask = bit0 ; Mask word for the shiftout proceedure
Symbol index = b1 ; Bit counter for shifting data
Symbol track = w1 ; Pointer to the required track file
Symbol dat = w2 ; Data to send to module is a word(16-bit) value
Symbol msb = $8000 ; Mask for the most Significant Bit = bit 16
Symbol sdat = b.4 ; Serial data output is on pinb.3
Symbol clk = b.5 ; Serial clock output is on pinb.2
Symbol busy = pin1 ; Busy line back from module
Symbol rset = b.6 ; Reset line for WVT020 device
Init:
Low sdat ; Data line Low
High clk ; Set clock to high on WTV020 device
High rset ; Set reset line high on WTV020 device
Pause 2000
Main:
track = 6
Low rset ; Reset the device
Pause 5 ; For 5ms reset pulse
High rset ; then high again
Pause 300 ; Delay 300ms
dat = track ; Load track number into dat
Low clk ; Pull clock-line low to start
Pause 3 ; Start-bit time >= 2msec to indicate a start of command
For index = 1 To 16 ; loop for each of 16 bits of filename/number
mask = dat And msb / msb ; mask out the most sig. bit to ascertain if next bit is 1 or 0
Low sdat
If mask = 0 Then Skip ; check if current data bit is "0" skip if it is a zero
High sdat ; set data line high only if the data bit is a "1"
Skip:
If index = 16 Then Skip16th ; Skip here as 16th bit is clocked out at the end
Pulsout clk, 20 ; Create 200usec clock pulse for the current data bit
dat = dat * 2 ; shift data one bit left
Skip16th:
Next index ; Get next bit till all 16 bits of data presented to module
High clk ; Pull clock-line high which also clocks out the 16th data bit
Pause 3 ; End-bit minimum time >= 2msec for STOP indication
Low clk
Low sdat
End
