Happy Holidays to all!!
while having a little time off, and received mail from china.
decided to tackle on IR controller/receiver with picaxe!
this is the item Bought:
http://www.ebay.com/itm/HX1838-Universal-Infrared-Remote-Control-Receiver-Module-NEC-Code-IR-Kit-Set-/321560823227?pt=LH_DefaultDomain_0&hash=item4ade84c5bb
followed the wiring and code from the manuals, but realized the controller that came with unit would not work.
tried other controllers and some do give a reading! but very little 2 buttons at most.
code used is:
irin [1000,main],1,W1
sertxd( "Key code = ", #W1, cr, lf )
like mentioned on some other controllers I have laying around I get 2 buttons at most and reads on terminal 123 or 1562.
did a Little more research and found out the controller supplied uses NEC Code not sony.
data:
http://techdocs.altium.com/display/FPGA/NEC+Infrared+Transmission+Protocol
Would there be a way to have the 28x1 decode the NEC IR Code so I can use the controller supplied?
Thanks all!
code used is:
data:
Thanks all!
