Hi All
I want to monitor a 8x8 switch matrix existing in a keyboard that is being scanned at 250Hz. I was thinking to tap into the inputs from the rows and columns and feed them to a port each. So i would look at the rows wait for a low on one of the eight lines and when detected look at the columns to see which was low to determine what switch was being pushed.
Would this be possible on a 28x2, would there be enough time to monitor for a low on the row inputs and when detected look to the column inputs to see which column it was?
If this would be possible can i get a few pointers as to where to start?
Or can someone advise a better solution?
Thanks
Daniel
Thanks
Daniel
