AXE401 Power Supply - ID/OD/Shaft len. missing in manual
domwild
To make a 9-12V supply for this proto board requires a "2.1mm centre (tip) positive connector", so the manual says. To buy the plug requires a little bit more than that, namely internal-, external diameter and shaft length of the plug. Anyone with a black belt in electrickery to supply that info?
domwild
Thanks, Pete. I know what a coax power connector looks like BUT which one suits the Pixace, that is another affair. Now I can go to Jaycar or Altronics and order correctly by part number without opening the proto board's package and fiddling with the socket until one fits. Thanks once again.
Do you also go by the name of Downwind??
