I am on somewhat of a soliloquy here, but,
I pulled trigger on axe110 + RTC upgrade.
Ordered directly from Rev Ed UK.
It's not dirt cheap @ $60, but if it works, worth every penny.
I'm wanting to get temp readings from say 50-350C, and thermocouples are the
industry standard for that.
As a chemist, I am interested in getting accurate melting points. The range over which the melt
occurs is as important as the absolute value, since impure substances melt gradually.
The main thing that is missing is a way to control the heater. I have had luck with the scr blocks sold on ebay directly controlled by the picaxe.
The idea is to control the heater with a periodic signal like pwm. I am confident of that, since I have done it before.
In developing this, several challenges are:
-loading the eeprom with K values.
-writing code using to measure heating rate.
-recording start and end temperatures, or raw delta V over the range.
-connecting an OLED or similar readout
Thanks in advance,
JB
