Thanks for the amazing upgrade job, well done guys.
I have some questions before switching completely to PE6:
1) When starting a PE5 single *.bas file in PE6 with legacy mode it still saves a file extra called *.bas.settings.
4) Font doesn't display special symbols anymore like ^, ° etc. Therefore can't make sense of my remarks. How to overcome?
5) Variable name declared when reading as a Symbol name rather then "A.1" and "ADC 1" notation. Could this be implemented: If SymbolName =1 Then... ?
Is it necessary when sending code to someone to include the *.bas.settings file?
2) Some PE5 wizards are missing in PE6. Where to find in PE6?a) X2 conversion.
b) COM to TCP/IP.
c) Convert Basic to Assembler.
d) AXE901 Dacto Viso Controlite.
e) NET001 PICAXE Net Server.
3) Missing horizontal scrollbar replaced by enter-arrows after every line thats wider than the screen. How to switch to horizontal scroll without enter-arrows like PE5?b) COM to TCP/IP.
Symbol InputValue = A.1 'When I want to change the pin to A.5 then it would only be necessary in this declaration!
ReadADC InputValue, VaccuVoltage 'Works well for analog!
If InputValue=1 Then 'Not supported yet for digital! Instead of: If PinA.1=1 Then
