parallel tasks
curtis_1966
I would like to thank everyone for your help on my last problem that I had, some great minds here. So here's my latest problem.
I have 3 tasks running(start0,start1,start3), start0 and start3 are in a loop routine now how do I stop start1 from falling into the other lines of code.
Thanks Curtis
Not sure that I fully understand your program structure from the description.
Please post your code so folks are clear on what you are doing.
The multiple tasks with M2 parts are I believe intended to be functionally separate.
Any reason why there is no Start2: label ?
From PICAXE manual 1 page 64:
sub-procedures can be shared between different tasks if required, however this is not generally recommended.
curtis_1966
oh sorry for that, my fault there. Was at work an in a rush to get out an no copy of code on me.
So start0: falls into a testit: loop and start1: just ends would fall into start2: and stop didn't seem to work it also stopped start0:. Any help would be gratefully appreciated.
(code)
start0:
for b15=1 to 60 ;Delay for PIR
next b15
serout TENDA,4800,($EF) ;STOP MP3
pause 500
serout TENDA,4800,($E7) ;Set MP3 Volume
pause 500
testit:
Do : loop until PIR_IN=1
PIR_COUNT = PIR_COUNT + 1 * PIR_IN
loop until PIR_COUNT = 10
PIR_COUNT = 0
goto turn1
Start1:
pause 500
MovementType = 0 ;reset movement type index to first data block
LastCommand=$ff ;show no last command
Random_Word=RandomSeed ;start random number off with random seed
ReadPointer=MovementType+HeadTurnData+HeadCenter
Read ReadPointer,Temp_LSB ;get default position for servo
servo HeadTurnServo,Temp_LSB ;and setup servo with it
TurnPos=Temp_LSB ;and the software too
ReadPointer=MovementType+HeadNodData+HeadCenter
servo HeadNodServo,Temp_LSB ;and setup servo with it
NodPos_MSB=Temp_LSB ;and the software too
NodPos_LSB=128 ;make it x.5 for round off
ReadPointer=MovementType+HeadTiltData+HeadCenter
read ReadPointer,Temp_LSB ;get default position for servo
servo HeadTiltServo,Temp_LSB ;and setup servo with it
TiltPos_MSB=Temp_LSB ;and the software too
TiltPos_LSB=128 ;make it x.5 for round off
stop
start2:
pause 2000
MovementType=0 ;yes, set the index to start of table
high EyesOutput ;and set Eyes output
Temp_LSB=7 ;and do all 7 movement types
turn1:
suspend 2
pause 500
serout TENDA,4800, (01) 'Play MP3
pause 500
servo B.2,210 'turn head
servopos B.2,210
for b16=1 to 5 'delay for mp3
next b16
servopos B.2,130 'turn head
pause 500
resume 2
for time = 1 to 150
pause 2000
next time
goto testit
Random Random_Word ;get next random number
Temp_LSB=Random_MSB * Temp_LSB /256; ;get a random from 0 to 4 or 0 to 6
if LastCommand = Temp_LSB then start2 ;get another command if repeating the last one.
On Temp_LSB gosub LookHome,LookFarLeft,LookNearLeft,LookFarRight,LookNearRight,LookAt,NodNo
Goto start2
curtis_1966
okay gonna try a do:loop until PIR_IN=3 at the end of start:1. Since it will never reach 3, if any better ideas let me know please
curtis
Update: seems to work fine in the windows simulator.
It is unclear exactly what the program flow is that YOU want, as opposed to what the program is doing.
I do not know whether the label testit: is supposed to be part of task Start0 or not. Your words suggest maybe not.
When positing code, please use the [code] and [/code] tags to retain any indentation.
If your code does not already have indentation please consider to add in future to make the code earlier for those helping to read and see the flow.
By way of example here is your code with some formatting and moving two blocks around so I could better see what might be the program flow for each task.
Can you see how much easier it is to see the labels and what lines are loops (For...Next or Do Loop structures, etc)
start0:
   next b15
   pause 500
   pause 500
testit:
   PIR_COUNT = 0
goto turn1
turn1:
    suspend 2
    pause 500
    pause 500
    servopos B.2,210
    next b16
    pause 500
    resume 2
    for time = 1 to 150
        pause 2000
    next time
    goto testit
Start1:
    pause 500
    stop
start2:
    pause 2000
    Temp_LSB=Random_MSB * Temp_LSB /256	; ;get a random from 0 to 4 or 0 to 6
    Goto start2
