For...Next Loop Problem?
tracecom
The for...next loop compiles for an 08M2, but doesn't produce the results expected. It seems that the Sum = Sum + Adval isn't working. What am I doing wrong? Thanks.
Symbol ADVal = W0
Symbol Sum = W1
ADVal = 0
Sum = 0
for ADVal = 1 to 8
	readadc 4, ADVal
	Sum = Sum + ADVal
next ADVal
ADVal = Sum / 8
for ADVal = 1 to 8
	readadc 4, ADVal
You are overwriting the ADVal FOR-NEXT index variable when you read the ADC. That is disrupting the FOR-NEXT loop. Use a different variable as the index variable.
tracecom
for ADVal = 1 to 8
	readadc 4, ADVal
That fixed it. I knew I was doing something stupid, but I could not figure out what it was. Thanks.
