I'm running this code and I can tell that it's working because the Emic 2 module speaks to me. Also, I can see the Xmit and Rcv data on my PC scope. The hserptr value in code explorer increments by 2 each time it speaks. I'm assuming this indicates that it is rceiving 2 bytes of background data. However I can't see any data in the code explorer scratchpad. What am I doing wrong? Thank you, Jims
[color=Green]'*** 20x2 drives an Emic 2 text to speech module.
'*** hserout on pin 10 (C.0) green wire.
'*** hserin on pin 12 (B.6) white wire.[/color]
[color=Navy]#picaxe [/color][color=Black]20X2 [/color][color=Green]; Define the ?Processor IC Type[/color]
[color=Blue]hsersetup B9600_8[/color][color=Black], [/color][color=Navy]%001[/color]
[color=Black]main:[/color]
[color=Blue]pause [/color][color=Navy]3000 [/color][color=Green]'Pause while Emic 2 initializes.
[/color][color=Blue]do
debug
pause [/color][color=Navy]5000 [/color][color=Green]'Pause long enough for the message to finish.
[/color][color=Blue]gosub [/color][color=Black]Speak1
[/color][color=Blue]loop
end[/color]
[color=Black]Speak1:
[/color][color=Blue]hserout [/color][color=Navy]0[/color][color=Black], [/color][color=Blue]([/color][color=Red]"S"[/color][color=Black], [/color][color=Red]"Testing 1 2 3"[/color][color=Black],[/color][color=Blue]cr) [/color][color=Green]'Xmit speaking message.
'hserout 0,("W190",cr) 'Set speaking rate to 190 WPM.
[/color][color=Blue]return[/color]
