" Live " Axepad
hitsware
I would like to make a bootable 'live' USB stick with Axepad included.
As small as possible. (but preferably with persistence)
Can anyone steer me in the right direction ? (the best distro) ?
I'm not fluent with Linux, so need a sure, simple approach.
Thank You :)
Puuhaaja
I have used that program which nick12ab recommended many times and it has worked well. There was some limitations which can't make working as persistence and I don't remember much about those. Anyways those limitations can be seen when you read some info from their website.
edit: Copied from their website
What can I do and not do on a persistent system?
You have to keep in mind that a persistent system is a Live system on which there is an overlay that is writable.
This means that core files are in read-only mode while other files are in read/write mode.
What you cannot do on a persistent system:
updates core files (kernel, etc...) = no full system updates
install drivers
What you can do on this kind of system :
install some software
do some software updates
create some files/folders
install Linux (from you USB key) on your PC's hard drive
