Need to know code to interface mcp23017 i/o exp via i2c
B-Joe
Hi, evry one.
Can some one please help me with a code to interface
an i/o expander via i2c to my 14m2 in order to connect a 3x4
keypad to my alarm project.
Thnx a lot.
Thanks to the westaust55 tutorial on the mcp23017:
#picaxe 14M2
SETFREQ M16
SYMBOL mcp23017 = %01000000 ; $0100 A2, A1, A0, R/W all connected to 0V
SYMBOL IODIRA = $00 ; Port A IO Direction register DEFAULT = I/P
SYMBOL IODIRB = $01 ; Port B IO Direction register DEFAULT = I/P
SYMBOL IOCON = $0A ; IO Expander config register - address $0B accesses the same register
SYMBOL GPIOA = $12 ; Port A General purpose register
SYMBOL GPIOB = $13 ; Port B General Purpose register
SYMBOL OLATA = $14 ; Port A latch register
SYMBOL OLATB = $15 ; Port B latch register
  pause 8000
  HI2CSETUP i2cmaster, mcp23017, i2cFAST_16, i2cbyte
'  HI2CSETUP i2cmaster, mcp23017, i2cSLOW_16, i2cbyte
  PAUSE 400
  HI2COUT IODIRA, ($00) ;set all port A pins as outputs (0)
  HI2COUT IODIRB, ($FF) ;set all port B pins as inputs (1)
   PAUSE 100
    HI2COUT GPIOA, (%11111111) ; all ON
    PAUSE 4000
    HI2COUT GPIOA, (%00000000) ; all OFF
    PAUSE 4000
'    sertxd("t")
    HI2CIN GPIOB,(b2)
    sertxd(#b2)
B-Joe
Westuast 55 tutorial re code for mcp23017.
#picaxe 14M2
SETFREQ M16
  pause 8000
  PAUSE 400
   PAUSE 100
    PAUSE 4000
    PAUSE 4000
'    sertxd("t")
    HI2CIN GPIOB,(b2)
    sertxd(#b2)
THanx so much guys. You are the best!!!
Mark.R
Been doing bits of research on this expander chip and i2c in general, its been interesting. How would the example of Westaust55 code changed/posted by Ibenson change to address more than one MCP23017 having the same A as out and B as input?
Not certain this answers your question, but for instance
; MCP23017 register address constants (from westaust55 tutorial)
SYMBOL mcp23017_0 = %01000000 ; $0100 A2, A1, A0, R/W all connected to 0V
SYMBOL mcp23017_1 = %01000010 ; A0 connected to +V
SYMBOL mcp23017_2 = %01000100 ; A1 connected to +V
  ' set up mcp23017 i/o expanders
  HI2CSETUP i2cmaster, mcp23017_0, cI2CSpeed, i2cbyte
  HI2COUT IODIRB, ($00) ;set all port B pins as outputs (0)
  HI2COUT GPIOA, ($00) ;set port A pins
  HI2COUT GPIOB, ($FF) ;set all port B pins as inputs (1)
  HI2CSETUP i2cmaster, mcp23017_1, cI2CSpeed, i2cbyte
etc. as needed to set or read after having issued HI2CSETUP for the appropriate mcp23017.
