; PWM train controller 6 June 2013 HN
; using 08M2 chip
; C.2 is the PWM output
; C.1 is encoder A channel
; C.4 is encoder B channel
; C.3 is emergency STOP
; b0, b1 and b2 are locally used byte variables
; 22 June 2013 some mods after testing it in circuit
; the increment needs to be bigger than 4
; I need to debounce the emergency stop switch
; set a symbol for decrement as well
; This version - look for a change in the B channel as well
; also different values for the step in increment and decrement
symbol dutyCycle = b0
symbol oldStateA = b1
symbol oldStateB = b2
symbol encoderA = pinC.1
symbol encoderB = pinC.4
symbol stopButton = pinC.3
symbol ModulatorOutput = C.2
symbol dutyCycleMaximum = 194
symbol dutyCycleMinimum = 0
symbol dutyCycleIncrement = 5
symbol dutyCycleDecrement = 7
pwmout ModulatorOutput,50,0 ; set up PWM channel and set it off
; initialise the variable that holds the old state of encoder A channel
if encoderA = 1 then
oldStateA = 1
oldStateA = 0
; initialise the variable that holds the old state of encoder B channel
if encoderB = 1 then
oldStateB = 1
oldStateB = 0
init:
dutyCycle = 0 ; initialise the speed variable
; main loop
if stopButton = 0 then ; check for emergency stop
pause 8 ; debounce
pwmout ModulatorOutput, 50, 0 ; stop pwm output
goto init
if encoderA <> oldStateA then ;has encoder A changed state
pause 4 ;slight delay
inc oldStateA
if oldStateA >1 then
oldStateA = 0
endif ; toggle oldStateA
if encoderB <> oldStateA then
; clockwise
dutyCycle = dutyCycle + dutyCycleIncrement ;increase speed
if dutyCycle > dutyCycleMaximum then
dutyCycle = dutyCycleMaximum
; anticlockwise
if dutyCycle > dutyCycleDecrement then ; decrease speed
dutyCycle = dutyCycle - dutyCycleDecrement
dutyCycle = 0
pwmduty ModulatorOutput, dutyCycle ; set pwm output
if encoderB <> oldStateB then ;has encoder B changed state
inc oldStateB
if oldStateB >1 then
oldStateB = 0
endif ; toggle oldStateB
if encoderA = oldStateB then
; clockwise
; anticlockwise
dutyCycle = 0
end
