Sale: $8 Rev Ed CHI030A Project Boards for PicAxe 18's
erco
Sale: $8 Rev Ed CHI030B Project Boards for PicAxe 18's
June 7 EDIT: The boards I received are the CHI030B version, which do not require any modification.
US buyers: Solder a little, save a lot. Sparkfun is discounting Rev-Ed's CHI030A board which has an error which is easily rectified per description:
Note: Our latest shipment of these boards have an error. The error is remedied by soldering in a small jumper wire (or solder jumper) and only affects those needing to use the B.0 output. The new revision of this board will ship without this error. You can view the instructions here.
https://www.sparkfun.com/products/8330 Only 24 remaining since I ordered my 10, which qualified for free ship (over $75).
ULN2803 darlington driver is included, PicAxe is not. Yanks, see http://www.phanderson.com/picaxe/ for 18M2+
We suspect this is probably a website mistake, as they have purchased many batches of the new board.
erco
Will advise, my order should arrive soon. If they are selling perfect, new boards for $8, even better.
erco
Right you are, Technical. I received the CHI030B board, which has no error and is ready to go. I verified the connections with a multimeter. This good deal just got better! 21 in stock now.
vintage radio
What $2 steppers on ebay are you referring to? Are you using a dedicated driver chip between the board and the motor, or are you driving the motor directly off the board?
Thanks!
