Using an L293D
lstrike
I am working on a miniature tank that uses a Tamiya Double Gearbox and an L293D motor driver chip.
After researching information on the parts I'm using and soldering them together, the circuitboard looks like this:
However, when I try to test the motors by typing "high b.2", the motors don't respond at all. They still respond when I connect them to a 3V source.
The motors I'm using are 2 3V DC motors that came with the Double Gearbox. Any help on this would be appreciated.
SAborn
That is because you are only switching half of the H-bridge, you need to switch both halves together for each motor.
Example for motor 1 .......
high b.2
low b.3
Then to reverse motor 1 ...
high b.3
low b.2
Bill.b
You do not require the 3 diodes for the motor supply. The Tamiya Double Gearbox will run happily on 5v
You would require 0.001uf capacitors across the motors to minimise noise effecting the picaxe.
Bill
