Use variable to set qualifier
KeithRB
I am reprogramming the 18M2 in the OLED. I am trying to display GPS stuff coming in over a bluetooth modem. I would like to select various NMEA sentences for display and create a subroutine to do that. Is there a way to use variables to set the serin qualifier?
geoff07
I haven't tried it, but I would expect any byte variable to do the job. Just assign the value you want to the variable and use the name of the variable in the command.
Yes -
b1 = "A"
b2 = "B"
b3 = "C"
Serin PIN, BAUD, ( b1, b2, b3 ), ....
Is just the same as -
Serin PIN, BAUD, ( "ABC" ), ....
geoff07
It is true that Picaxe does not recognise string variables, or have string functions. And yet .. in practice, bytes containing ascii character codes and stored contiguously are a string in some limited ways.
Strings can be used in some places within PICAXE commands. They aren't strings as such but separate character bytes -
Is really a shortform for -
Serin PIN, BAUD, ( "A", "B", "C" ), ....
KeithRB
Which is why I was confused...
I am pretty language agnostic, (Well, except for BF), but I really wish subroutines had their own variable space.
geoff07
A problem with implementing block structured languages with local variables is all the context saving and restoring.
However, the recent presence of push and pop lead one to wonder if functions are around the corner ..
Thanks for that, but I have to use the 18M2 since that is what you guys put on the OLED. 8^)
On non-X2's it is possible to use the RAM and 'bptr' variable to implement a LIFO stack and use macros to create PUSH and POP equivalents ...
#Picaxe 18m2
#Terminal 4800
#Macro PUSH(bytevar)
  dec bptr
  @bptr = bytevar
#EndMacro
#Macro POP(bytevar)
  bytevar = @bptrInc
#EndMacro
Pause 2000
For b0 = 1 To 10
  SerTxd( #b0, " " )
  Gosub MySub
  SerTxd( #b0, CR, LF )
Next
End
MySub:
  PUSH(b0)
  b0 = 99
  SerTxd( #b0, " " )
  POP(b0)
KeithRB
#Macro?
What is that? I guess it is time to download a new picaxe_manual2!
But great idea, hippy! I will have to see if I can spare any RAM from my serial buffer!
ETA:
It might be a good idea to put a revision number in the manual file name.
