stevesmythe
Is there any way to specify the address to go to when using the timeout parameter? (i.e. the equivalent of "IRIN [timeout, address], pin, variable"). I see that there is a checkbox which generates the equivalent of "IRIN [timeout], pin, variable" but I don't see any way of specifying an address to go to on timeout.
I want to use the command to control robot motors and turn off the motors if no key on an IR TV remote is pressed.
